View Full Version : I can't find a couple of bolts.....
Samckitt
06-05-2007, 09:21 AM
These are both metric, grade 10.9 (8).
One of them is 14x2.0x30
The other is 12x1.75x15
Anyone know where I can get these? I found the 14mm one in the correct size, but was grade 8.8 (5). Factory used 10.9 & would rather stay with that. I have the factory bolts, but for what I am doing they are too long. I have 5/16" of washers as spacers on them, but would rather have the correct length.
TitoJones
06-05-2007, 09:43 AM
McMaster-Carr has them both in either black or zinc plating. The 12mm is going to be tough to find that short however, it seems they start out at 20mm.
The 14mmx2.0x30mm is PN 90854A256 in Gold zinc and PN 91310A762 in black oxide.
The 12mmx1.75x20mm is PN 90854A22 in gold zinc, and PN 91310A706 in black oxide.
The gold bolts come in packs of 10 and the black come in packs of 25.
Hope that helps.
Oh yeah-
www.mcmaster.com
Tyler
Jim Nilsen
06-11-2007, 06:11 AM
If the thread won't bottom out on the shank below the bolt head you can cut 5/16 off and re shape the end on the grinder or just grind it all off. I have had to make bolts shorter many times when factory fasteners weren't around. It won't change it's performance to hold things together that I have ever experienced! Now if you were too short and needed longer ones you would have the need for new.
Samckitt
06-16-2007, 06:23 AM
I thought of that, but they were to hold the front & rear calipers on so I didn't want to mess with the bolt hardness. I found them at Fastenal last week. They had to order them, & I was able to buy them individually instead of a box.
