View Full Version : Engine hoist lift plate?? concern
LowBuckX
06-02-2007, 11:10 PM
Im pulling my motor Sunday (today) or next week. Some how my chain went missing. (borrowed never returned)
ONe of those carb base lift plates would be cheaper than buying a length of chain but Im having a hard time trusting 4 5/16 bolts to do this job. Am I wrong to be skered?
https://static1.pt-content.com/images/pt/2007/06/rus611060_w-1.jpg
68sixspeed
06-03-2007, 06:19 AM
I've never heard of one dropping and I've pulled a lot of motors with them, even big blocks. I just wouldn't use cheapo mr-gasket carb studs or cheap/short bolts..
Scott Parkhurst
06-04-2007, 01:33 PM
I didn't trust the carb plates when I first saw them either (like 1990)...but after slinging at least 100 engines around with them, they've won my confidence.
Trust it - it'll be fine.
~SP~
parsonsj
06-04-2007, 01:55 PM
With data:
A 5/16 bolt has between 3900 lbs (grade 2 course thread) to 8700 lbs. (grade 8 fine thread) breaking strength.
Since you're using four of them your engine would have to weigh more than 15000 lbs even using the weakest grade and thread.
You'll be ok.
jp
the camtender
06-04-2007, 04:39 PM
Done bbc with 400 trans attached a dozen or so times,no worries
Adam's 55 Chevy
06-05-2007, 02:02 AM
One thing, just dont do the bolts up sooooo tight you pull the threads from the intake.
