View Full Version : LS7 62 Belair Bubbletop Update
BLT2DRIVE
06-02-2007, 10:54 PM
Motor and tranny are in,headers made,drive shaft in, power steering lines in, can start adding fluids.Have to relocate some wiring under the dash after taking out the LS6 / 4L60E, and putting a clutch pedal in. Don't want to pinch or cut the wires now that the pedal throw is working there.
cspengler
06-05-2007, 09:09 AM
Hi,
What oil pan did you use?
Your car is looking very good, and i love the blue paint job.
Chris
BLT2DRIVE
06-05-2007, 09:13 PM
It's the stock LS7. I had an LS6 with a Camaro pan before and it actually had more room. The Camaro pan is 1 1/2" deep at the front and the LS7 is 2". I heated the kink in the K member and knock the bend in a 1/4", only needed it on the pass. side to give a little room for movement. Drivers side was clear .
