MonzaRacer
06-01-2007, 08:49 PM
Well what do you get with guys who have nothing to do but mix and match old parts destined for the scrape yard?
We took a 267 block(factory 3.5x 3.48) junked the crank and then we took a 262 crank(3.621 bore i thinkx 3.1 stroke).
We used some longer rods and the 267 pistons and turned the tops down someand they fit of course(we thought this up as we had a set of stock 267 moly rings and a block with 27k on it and no ridge.
the cam as a 151 (350/327) cam we had laying around.
WE used a set of 305 Hi comp heads and an old 50s aluminum intake of unknown origin.
This wee beastie got stuck on a dyno and made 361 hp and 341 lb ft of torque and its so small. It Idles like a super stoker with that tiny cam and compression.
We used an old methanol 660 center squirter i had bought and we tweaked it on E85!
This POS is sweet,, my buddy who owns most of the parts wants my GM Heavy Duty Ignition (IE MSD 6T) and to put it in his Miata or RX7.
Even so tiny it screams! The wail from the dyno came over my computer a few minute s ago and i thought it was something outrageous.
So much for junk parts huh?
Lee Abel
AFTERMARKET PERFORMANCE
PS Ill try to post a link to the dyno pull audio. Long live red neck engine builds!
Lee Abel
