nkopper
12-22-2004, 05:47 AM
Once I get my minitub finished, I'll be sending my Ford 9" rearend to Moser to be narrowed. How far inboard from the stock location do I need to tell them to mount the spring perches since I'll be using DSE offset shackles? I can't use the DSE adjustable perches because my rearend is a heavy duty housing with 3.25" axle tubes. I will be using a set of universal (look kind of like Mopar style) perches from Currie. What should I have them set the pinion angle at? I'm thinking about 3 degrees.
Where can I get shock plates made to bolt to 3.25" axle tubes? Looking for inboard, staggered mount to fit the minitub. If none are available, I might have to have someone make me a set.
Thanks!
Nathan
Thanks!
Nathan
