My427stang
06-01-2007, 10:10 AM
I have a 70 Mustang, 489 cid FE, TKO-600 and currently a 3.70 nine inch. The motor is built for a very flat torque curve and peaks under 6000 rpm at approx 575 hp. Mild by stroker standards but not a truck motor
I run a 3.70 gear with a .64 OD to make a 2.36 final drive. The motor doesnt mind at all and will pull 5th gear happily down to about 1500 rpm, however, with a 242/248 duration solid lifter cam, its really not in its most efficient range
I am considering a 4.11 or 4.30 gear to get the final drive to a more usable 2.63 - 2.75 when in 5th
Any of you guys running that steep of gear? Seems like 1st gear will be a little short, but it should get it closer to about 2200 rpm on the highway when cruising, right now at 65 I am closer to 1800 rpm
Opinions? Just tossing ideas around right now, not really a "problem" but wodnering if anyone else has run that much gear with a TKO
Thanks in advance
Thanks in advance
