KendallF
12-21-2004, 07:02 PM
**Updated 10 January**
Changed the pictures below, since I finished the fuel rails and hold-downs. The intake's on its way back to the owner for powdercoating and getting the throttle plates & linkages put back on. The fuel rails were drilled for the injectors, the outer lower edge was beveled to allow the injectors' electrical connectors to clear, and the ends of the rails were drilled, tapped, and chamfered for a -8 AN O-ring fitting. I took a shot at polishing the rails as well.
**end update**
Thought some of you might be interested in how this manifold is coming along. Still have to do the matching fuel rails, fabricate hold-down brackets, etc..but I'm happy with it so far.
I started with angle cut 3/4" 6061 solid round stock, welded them to each runner using a wooden jig with 3/4" holes drilled to locate the bungs in 2 dimensions. My friend Tracy Grimm welded them..the 30 year old dirty casting would've defeated me. :)
Next was the Bridgeport; I milled them all to the same height, center drilled them into the port, and then drilled the opening the injector o-ring will seat in. A chamfer on the top of each one was the last operation.
**end update**
