View Full Version : speed sensor test
wayne70
05-28-2007, 08:36 AM
Doe's anyone know how to test a speed sensor on a gear vendor's overdrive? Trans. won't shift into overdrive and i think that the speed sensor is bad. THANKS
67 caprice
05-28-2007, 02:58 PM
I'm having some issues my self. I'm calling G.V. Monday I ask and will let you know.
67 caprice
05-29-2007, 08:54 AM
The speed sensor on a gear vendor's overdrive can be read on AC only.
Use a drill to turn the sensor. Voltage will increase to a max of 3.5 to 4 volts as RMP Increases.
wayne70
05-29-2007, 03:35 PM
Russ thanks for the info. I have found my problem to be the speeddo cable came apart inside the housing,less than 100 miles on it.Hope you have your's working now.
