View Full Version : wheel lock removal
tb8125
05-27-2007, 01:55 PM
Hey guy I got my car home a few days a go.. Now I want to take the wheels off but the wheels have locks on them... And I don't have the key them.....How do I go about removing them....
dropit69
05-27-2007, 02:11 PM
do you own a air impact ? i have seen my buddy pound large socket over them and zip them off might have to get 4 new lugs though..but it does work seen it with own eyes..
GetMore
05-27-2007, 02:20 PM
Most shops have the sockets for removing those locks, or any rounded off lug nut. They are kind of like easy-outs for nuts.
tb8125
05-27-2007, 02:34 PM
thanks guys I don't have a impact.... I saw a tool at pep boys but was not sure if it would work or not it looks kinda cheap
MonzaRacer
05-27-2007, 06:04 PM
http://www.steckmfg.com/
Try these guys the tools they have are tough and will do the trick for those and stripped lugs too. worth every penny spent if you dont like any local shops.
Lee
TUBED
05-27-2007, 08:43 PM
If you can remove the center cap and put visegrips securely on it and see if it'll move, as long as the the lugs aren't over torqued it should come off. A cold chisel and a hammer starting at 10 o'clock will also work taking your time.
Gerald
05-27-2007, 09:45 PM
your better off bringing it to a shop and have them impact off like Darrin suggested. if you wack em off wrong, say bye bye to them rims.
HotRod68Camaro
05-28-2007, 06:38 AM
tighten the **** out of the other lugs so that the lock will be a lil looser. then use a chisel and try to turn it. worked for me.
Young Gun
05-28-2007, 08:14 AM
i used a vice grip and manged to get mine off...you should give it a shot
MonzaRacer
05-28-2007, 09:31 AM
Another trick is get a buddy to weld a nut on the top of the ock and then remove it with regular socket.
I used card board over the lock when we do this and just wet it down before welding, also jack car up so slag and sparks wont melt tire.
