View Full Version : rotor ideas
viper11
05-21-2007, 09:42 PM
hi
i'm looking for some 13"-14" rotors for my charger
i will be using hubs to replace the factory style rotor with the 1 piece bearing hub/rotor
i need rotors with a 5 bolt pattern and a 2"(approx) deep hat to clear the viper calipers most newer rotors have very little hat to them
i've ruled out late model corvettes, mustangs, cherokees, gm trucks, 300's, vipers(6 bolt),
i have a limited budget so i can't do the wilwood/baer swap
porshe caymans would work but are almost a $1000 a pair
mercedes may work but i'm hoping someone can recommend some options
below is a pic of my original style rotor
i need something with a similar offset hat
thanks jason
deuce_454
05-22-2007, 01:26 AM
Ive been involved in an install where we used BMW rotors on the old hubs (believe the hubs were ford GVM thet were redrilled for GM pattern), not too expensive and excellent quality.. they have about 1.5-2 inch tall hats and come in sizes up to 14 inches... go down and have a char with your local parts guy and take a look at them..
viper11
05-22-2007, 05:55 AM
hey deuce
any particular era beemer???
p.s hat depth is the term I was looking for when i was typing it out duh
i will edit it to make more sense
thanks jason
bretcopsey
05-22-2007, 06:36 AM
I know Coleman Racing does custom rotors-if you can't find an off the shelf solution www.colemanracing.com (http://www.colemanracing.com)
They show solid mount
Custom Disc, Solid Mount
[21838]$134.35https://static1.pt-content.com/images/noimg.gifPart No. 21838
These heavy duty directional vane brake rotors are available in thicknesses from .900" to 1.100" and diameters of 11-3/4" to 13". These are custom rotors and are made to your specs. Please use chart for custom rotors on page 150 or provide a sample or blueprint.
And floating mount
Custom Disc, Floating Mount
[21839]$206.70https://static1.pt-content.com/images/noimg.gifPart No. 21839
viper11
05-22-2007, 07:12 AM
cool thanks i'll check them out
jason
matthimself456
05-22-2007, 01:02 PM
Maybe use circle track style seperate hats and rotors. Check out muscle motorsports for cheap used stuff. Hats come in a bunch of depths and as long as the rotor mounting bolt circle is the same as the rotors you want to use you can get pretty much any size you want. As an added bonus they look super trick and the lighter aluminum hat slightly decreases rotating inertia and unsprung weight.
