View Full Version : If a show car burns is it still worth rebuilding?
brrymnvette
05-21-2007, 06:23 AM
I'm looking at a 68 Camaro that burnt. It was a show car before the fire. Is the metal and stuff worther reusing?
paul67
05-21-2007, 06:38 AM
Depends if the panels buckled
TA219
05-21-2007, 07:07 AM
ditto, the panel warpage would probably be enough to cause several headaches, plus every car i have ever seen burn usually rusts up pretty quickly so you are fighting that too.
I guess it depeneds on how bad the fire was
6'9"Witha69
05-21-2007, 08:13 AM
People have started with less.
Restomod
05-21-2007, 12:56 PM
If it burned bad enough the owner did not fix it you can bet every panel is warped.
MonzaRacer
05-21-2007, 08:12 PM
Bret Voekel President of Air Ride Technologies 71 Prostreet Mustang was in a fire if I remember correctly. I do know one of his old cars was in fire and rebuilt.
Im not a body guy, Jim and Mike are... but I wouldn't think that would be a very solid foundation to start with. Why not look for a car that doesn't have baggage?
Restomod
05-23-2007, 04:39 PM
:postpics:
LateNight72
05-23-2007, 05:53 PM
Not only the warpage from heat, but also the warpage from the fire hose (if the Fire Dept. responded) would be excessive...
bookends
05-23-2007, 06:00 PM
also the fire dept isn't exactly gentle to the body panels when it comes to opening hoods and such to access where the fire is.
