View Full Version : Which "X" pipe to use big one or small style?
Steve68
05-21-2007, 04:17 AM
I have a universal X pipe kit, and I have a smaller X pipe, both are 3" pieces, is it going to make a difference on the size of the actual crossover the universal is 6" and the other one I have is 4 1/4 in area,
I going to look at the Dr. Gas site, and check but I thought, I'd ask around first,
This is for the Nova,
Steve68
05-21-2007, 09:18 AM
Dr Gas sez- go with the bigger one!
Josh
05-21-2007, 09:36 AM
With a lowered 1968 and a 3" system, you will have ground clearance issues. I needed to tuck my pipes inboard as far as possible and up into the shaft tunnel a little to maximize space and not be able to see the pipes hanging there. The narrowest X pipe is needed. I used a Dr Gas and did a bit of modification to it in order to make it work..
Excuse the welds, this was during mock up and they were not ground down yet!
https://static1.pt-content.com/images/noimg.gif (http://img443.imageshack.us/my.php?image=1737385ir4.jpg)
Steve68
05-22-2007, 05:48 PM
I should have noted this is for the Nova, no clearance issues, YET!
Looks pretty good so far,
