View Full Version : c6 wheel? on 68 camaro
lowapache
05-17-2007, 11:48 PM
i have a 68 camaro all stock i am going to drope it with dse leaf spring and dse front drop spring i want to put 06 corvette wheels my question is what size spacer will i have to put on to make them fit and what size tire will i have to run the rims size are 18 in front and 19 in the rear
Project69
05-21-2007, 05:14 AM
For the front you will need to run a 2'' spacer if the rim is 9.5'' wide, but what size tire will you bu using because since you are lowering it your gonna need to clearence alot of things first, mainly fenderwells. Im running a 255/45/17 tire and the front is lowered more then yours will be but since its an 18'' rim you might run into more issues then i did with mine.
As for the rear im not so sure on that one, the 19'' rim is 11 inches wide and im not sure of the right offset youll need for that one. I used a 2-1/4'' for my rears and im using the Z06 18 x 9.5 and it fits perfect. maybe you can use that measurement for something lol
