View Full Version : Identity Crisis - 72 El Camin SS??
dan10101
05-17-2007, 10:22 PM
Identity Crisis 1972 El Camino SS
It is a car, or a truck. Is it a SS or just a wanabee. Is it stock or PT.
Every indication says it is indeed an SS 350 4 speed born in California. Originally a pale yellow with black stripes. It spent some time as a drag strip runner. Still has a roll bar that was hacked thru the floorboard and welded to the frame. The lack of a single piece of physical proof allows me the freedom to do pretty much whatever I want to the car. Which I am.
I bought it a year ago with a newly rebuilt 402 Big Block, build turbo 400 with floor B&M shifter and newly built Pontiac 12 bolt Posi with 3.42 gears. It was already on it’s way to a life in Pro Touring. The front suspension was rebuilt and stiff lowering springs were added along with very large sway bars front and rear. 17” Hopsters with 245/45 tires. Factory buckets and an SS dash among the other trashed interior.
The goal for this vehicle. I need a truck. And I’ve missed owning a muscle car since the early 80s. So I decided to make a modern truck with classic appeal. It’s duties will be Car shows and runs, cruising, towing a sports car to the track, occasional drag strip run, and generally causing a stir when it drives by.
I have a lot of work to do on this. Paint, interior, suspension, brakes. I'll give more info as things solidify.
https://static1.pt-content.com/images/pt/2007/05/HPIM1979-1.jpg (http://s719.photobucket.com/user/dan10101/media/El%20Camino%20Build/HPIM1979.jpg.html)
https://static1.pt-content.com/images/pt/2007/05/HPIM1977-1.jpg (http://s719.photobucket.com/user/dan10101/media/El%20Camino%20Build/HPIM1977.jpg.html)
I just figured we need more Ekly representation.
Dan
00fxd
05-19-2007, 02:00 PM
Nice El Camino. Weren't all El Camino's built in Calif?
dan10101
05-19-2007, 03:25 PM
Thanks, My little thread was dieing a quick death.. :sick:
Don't know about Ca only. I haven't heard that in my short time of ownership.
I was thinking that CA wasn't allowing the sale of 4 speed cars back then, maybe I'm wrong. This originally came with a 4 speed so I may be wrong about it's heritage.
Here's some rust carnage. Everyone loves rust..
Actually it's pretty good, I think the heater or AC leaked on the floorboard and they never did anything about it.
dropit69
05-19-2007, 04:15 PM
looks pretty darn clean ..ill trade you a midwest car that year..lol..i had a 80 camino..rusted clean through..i would have keep it if it was as clean as yours..good luck keep us posted on progress..
dan10101
05-19-2007, 04:44 PM
Thanks Darrin,
I do know we're fortunate out west. It had more rust in the sugglers bay, but it was repaired from the inside so well that it looks like factory. But the wierd thing is they left the rusted part on it so from the bottom it looks like swiss cheese. I'm going to try to trim it of when we do the undercarriage, but it's not doing any harm for now.
We did some rust repair on my Son's 914. It looked real good when we bought it, but still had a bunch of rust to deal with. He has a 350 Chevy in it now. Widebody and full suspension. We'll be towing either this or my 944 with the El Camino. They both are capable of driving to the track, but after driving hard at the track, it's nice to know it will make it home.
derekf
05-21-2007, 04:03 AM
My 69 was built in Kansas City (K code).
dan10101
05-21-2007, 09:56 PM
Now that you said that, I had to check again. Yup, it was L Van Nuys. Not that it matters. But, just because it was built here, doesn't mean it was sold here. Anyway, it probably was. Seems like the mid 70's is when Ca started cracking down on those heathen 4 speeds.
Got my new brake kit today from Matt's Classics.
13" front and 12" rear. The calipers are factory Suburban and rears are factory Lincoln i believe. They are a bit on the heavy side, but should stop that little truck like (insert something that stops real fast here.)
dan10101
07-17-2013, 08:12 AM
Thread back from the dead, project back from the dead after 6 years of sitting on my butt. Frankly, I was having too much fun driving it to have it torn down for a long period.
Note, GM says the Elky is a "Coupe Utility Vehicle". Wiki says CUV is a "Crossover Utility Vehicle".
No excuses, but at least I'm finally moving forward again.
The brakes are on the car. I had to get different brackets for the 'Olds' rear end with Moser rear axles (no C-clips) but CPP set me up with what I needed.
Replaced upper and lower control arm bushings on the front. The rest of the front end was in good shape from a recent rebuild. Pulled the front lowering springs and shocks out and replaced with QA1 coil overs. I may go back if these are too stiff, but it's nice to have the height adjustable.
https://static1.pt-content.com/images/pt/2013/07/20130620204536-1.jpg (http://s719.photobucket.com/user/dan10101/media/El%20Camino%20Build/2013-06-20204536.jpg.html)
The sway bars have already been upgraded front and rear. But I added adjustable tubular control arms in the rear to get rid of a bit of dog walking. I pulled out the coil overs (overload shocks) on the rear and left the bags and lighter coil springs (out of an 84 elky) to try to get the rear end down a bit. Seems to be pretty good considering the size tires I have on there. I may have to spring for some lowering springs in the back. We'll see how the stiffness is in the front before I mess with it any more.
https://static1.pt-content.com/images/pt/2013/07/20130712194546-1.jpg (http://s719.photobucket.com/user/dan10101/media/El%20Camino%20Build/2013-07-12194546.jpg.html)
The body work is underway. Lots of sanding to do. Minor rust re-repair in the RS lower fenders.
https://static1.pt-content.com/images/pt/2013/07/20130712193127-1.jpg (http://s719.photobucket.com/user/dan10101/media/El%20Camino%20Build/2013-07-12193127.jpg.html)
Thank goodness my Son is a skilled welder, I just seem to blow holes in everything.
https://static1.pt-content.com/images/pt/2013/07/20130713201523-1.jpg (http://s719.photobucket.com/user/dan10101/media/El%20Camino%20Build/2013-07-13201523.jpg.html)
Sanded the hood yesterday, It came out pretty good, but had some weird lines from old hood stripes I think. Still, it's in good shape. On to other panels.
https://static1.pt-content.com/images/pt/2013/07/20130716211335-1.jpg (http://s719.photobucket.com/user/dan10101/media/El%20Camino%20Build/2013-07-16211335.jpg.html)
So, I'm finally making progress.
https://static1.pt-content.com/images/pt/2013/07/20130710204954-1.jpg (http://s719.photobucket.com/user/dan10101/media/El%20Camino%20Build/2013-07-10204954.jpg.html)
dan10101
07-17-2013, 08:51 AM
Some brake pictures. Sorry most of the pictures aren't the greatest...
Front
https://static1.pt-content.com/images/pt/2013/07/20130621220619-1.jpg (http://s719.photobucket.com/user/dan10101/media/El%20Camino%20Build/2013-06-21220619.jpg.html)
Rear
https://static1.pt-content.com/images/pt/2013/07/20130701201553-1.jpg (http://s719.photobucket.com/user/dan10101/media/El%20Camino%20Build/2013-07-01201553.jpg.html)
bs46488
07-17-2013, 09:51 AM
wow, that's a serious chunk of bondo. Glad the welder worked on the fix.
What part of the country are you in?
dan10101
07-17-2013, 10:30 AM
Central Cal. The hot spot. :)
Yes, fortunately the rust was minimum.
HELLCAMINO
07-17-2013, 05:38 PM
And now there are 3 semi Pro Touring 72 Elco's on this forum.....sa-weet!
Danny72
07-17-2013, 06:09 PM
Awesome to see another Elco on here! Instant subscribe!!
dan10101
07-17-2013, 07:13 PM
Thanks guys, I was reading thru your threads earlier today. Both really nice cars. I hope to keep it going. I've done some autocrossing too, just not with the Elko.
I just did a couple hour stint sanding the front end. That's about as much I can handle at a time. But I have to keep at it, even if only a little bit at a time. I don't want the project to go stagnant again.
walis
07-18-2013, 12:41 AM
Dan
way to go :grouphug: got me an -72 myself :-)
Yelcamino
07-18-2013, 03:29 AM
Yep, we need more El Caminos on this forum!
68firebird
07-18-2013, 04:04 AM
Love the el caminos! Keep it going, brakes look good!
dusterbd13
07-18-2013, 03:26 PM
giggity. another elco.
and for some reason, these things get the weirdest amount of attention from others. mines spray painted, for gods sake.....
but work good as a truck. you towed or done heavy hauling with yours yet? howd you like the air lift bags for that? im looking at a set for my 64 due to not enough payload capacity.
Michael
dan10101
07-18-2013, 05:33 PM
Hey Walis - Another 72 El Camino! That makes 4, keep um coming..
Love driving mine, that's why it took so long to dig into it. The engine is now a fuel injected 402ci big block with a torque build. It has a TH400 with a stiff shift kit and aftermarket shifter. It's fun to run around and chirp 2nd...
Michael, I haven't towed much, but hauled a bunch. The bags help a lot. I left them separated so I could add more air to the right one in case I did much drag racing. (that hasn't happened near enough). I also had a set of overload shocks on it, but one of the things I'm trying to do is to get it down in back, so they are off for now. I toyed with building a shock mount lower on the axle to keep them, and that may happen. As you can tell I'm on a real budget. Trying to do this rebuild with minimal purchases and my store house of new parts I've acquired over the years.
https://static1.pt-content.com/images/pt/2013/07/HPIM0033-1.jpg (http://s719.photobucket.com/user/dan10101/media/El%20Camino%20Build/HPIM0033.jpg.html)
https://static1.pt-content.com/images/pt/2013/07/haulingbrick-1.jpg (http://s719.photobucket.com/user/dan10101/media/El%20Camino%20Build/haulingbrick.jpg.html)
These pictures are prior to adding the overload shocks but after bags.
Oh BTW, this was close to 2000lbs when you add my wife and I to the load.
dan10101
08-24-2013, 09:28 PM
Summer Update.
I've made huge progress.... backwards...
I decided to take a look at repairing the rust that I could see in the smuggler bay area. It was only visible from the bottom. Many years ago I found the inside looked fine. I took another look at it from the top and found the false bottom pealing away. I dug out a large patch of galvanized sheet metal making it look repaired.
https://static1.pt-content.com/images/pt/2013/08/20130817130840-1.jpg (http://s719.photobucket.com/user/dan10101/media/El%20Camino%20Build/2013-08-17130840.jpg.html)
https://static1.pt-content.com/images/pt/2013/08/20130817164829-1.jpg (http://s719.photobucket.com/user/dan10101/media/El%20Camino%20Build/2013-08-17164829.jpg.html)
https://static1.pt-content.com/images/pt/2013/08/20130817164805-1.jpg (http://s719.photobucket.com/user/dan10101/media/El%20Camino%20Build/2013-08-17164805.jpg.html)
https://static1.pt-content.com/images/pt/2013/08/20130817183059-1.jpg (http://s719.photobucket.com/user/dan10101/media/El%20Camino%20Build/2013-08-17183059.jpg.html)
While I was in a deconstruction mood, I cut away the drivers floorboard.
https://static1.pt-content.com/images/pt/2013/08/20130822210422-1.jpg (http://s719.photobucket.com/user/dan10101/media/El%20Camino%20Build/2013-08-22210422.jpg.html)
The passenger floorboard was covered with a tar like substance that fortunatly came up very easy and apparently protected the area. Not sure why that side was ok and the other was not...
https://static1.pt-content.com/images/pt/2013/08/20130822210450-1.jpg (http://s719.photobucket.com/user/dan10101/media/El%20Camino%20Build/2013-08-22210450.jpg.html)
https://static1.pt-content.com/images/pt/2013/08/20130822210500-1.jpg (http://s719.photobucket.com/user/dan10101/media/El%20Camino%20Build/2013-08-22210500.jpg.html)
Much of the interior has been removed so I could repair and confirm that I was getting all the rust. Looks like aside from the know bad floor in the drivers floorboard, there are some rusted thru areas in the back of the seats.
More cutting to do here. We'll see how much as I start getting into it.
https://static1.pt-content.com/images/pt/2013/08/20130822210511-1.jpg (http://s719.photobucket.com/user/dan10101/media/El%20Camino%20Build/2013-08-22210511.jpg.html)
In the meantime, I've removed the interior (obviously), the front end leaving the fenders. The rear bumper and tailgate so I could repair a bad body bushing.
https://static1.pt-content.com/images/pt/2013/08/20130803130633-1.jpg (http://s719.photobucket.com/user/dan10101/media/El%20Camino%20Build/2013-08-03130633.jpg.html)
https://static1.pt-content.com/images/pt/2013/08/20130801192335-1.jpg (http://s719.photobucket.com/user/dan10101/media/El%20Camino%20Build/2013-08-01192335.jpg.html)
I finally found the rear e-brake cables so I moved calipers back of the axles so I could use them and I reinstalled the overload shocks, but modifying the lower shock mount moving the shock inboard and down to get the back down a bit. Did some detail work on the rear end allowing it to look as good as it works.
I'm hoping this will more closely match the stiff setup on the front.
https://static1.pt-content.com/images/pt/2013/08/20130807202521-1.jpg (http://s719.photobucket.com/user/dan10101/media/El%20Camino%20Build/2013-08-07202521.jpg.html)
Something else I'm working on is changing the exit of the exhaust. Currently it goes straight out the back. For me that just doesn't work. I want to hear the exhaust! So I'm turning the exhaust pipes so they exit out the side. No pictures yet, I hope I can get them even without resorting to a muffler shop.
Ordered the paint, primer and other necessities. Victory Red will be the color. Late model gm red. Single stage.
Lastly, I had some friends over and opened up the headers, (to do some welding on the exhaust).
So, enjoy the noise...
http://s719.photobucket.com/user/dan10101/media/El%20Camino%20Build/2013-08-13202131.mp4.html
I need to adjust the idle back setting on the fuel injection.
Still a long ways to do, but it beats sitting in front of the TV like I have for the last 7+ years.
dan10101
08-25-2013, 08:28 PM
The last photo doesn't show the coilovers. But now they do fit without rubbing on the calipers.
jlcustomz
08-25-2013, 09:25 PM
Glad to see you're making progress again. It sure can be hard between work & life to do so.
I got a real identity crisis project myself.
.https://static1.pt-content.com/images/noimg.gif (http://s1094.photobucket.com/user/jlcustomz1/media/DSC00710_zps302e496c.jpg.html)
dan10101
08-26-2013, 05:13 PM
jlcustomz
I would say so, Possibly a 'secret identity' :)
Nice work making that all fit together.
Dan
dan10101
11-16-2013, 09:26 PM
I'm overdue for an update.
I've spent the last 6 months working on the car at little at a time. I'm making some progress.
I've repaired the rusty floorboards and smugglers bay.
https://static1.pt-content.com/images/pt/2013/11/20130817183619-1.jpg (http://s719.photobucket.com/user/dan10101/media/El%20Camino%20Build/2013-08-17183619.jpg.html)
https://static1.pt-content.com/images/pt/2013/11/20130913145739-1.jpg (http://s719.photobucket.com/user/dan10101/media/El%20Camino%20Build/2013-09-13145739.jpg.html)
https://static1.pt-content.com/images/pt/2013/11/20130917151858-1.jpg (http://s719.photobucket.com/user/dan10101/media/El%20Camino%20Build/2013-09-17151858.jpg.html)
Removed the roll bar that was welded to the frame thru the floor. Squeaked like crazy because the floorboard was rubbing on it.
https://static1.pt-content.com/images/pt/2013/11/20130920152013-1.jpg (http://s719.photobucket.com/user/dan10101/media/El%20Camino%20Build/2013-09-20152013.jpg.html)
did my typical crappy welding job to seal things back up.
https://static1.pt-content.com/images/pt/2013/11/20130921213332-1.jpg (http://s719.photobucket.com/user/dan10101/media/El%20Camino%20Build/2013-09-21213332.jpg.html)
After finishing up the floorboards, I moved back to the body. Removed the doors and worked over the door jams.
https://static1.pt-content.com/images/pt/2013/11/20131115194554-1.jpg (http://s719.photobucket.com/user/dan10101/media/El%20Camino%20Build/2013-11-15194554.jpg.html)
After what seems like weeks of sanding and bondo work. I finally was able to tell my Son I was ready to prime. He came over this morning and helped the finish work, masking, prepping, and FINALLY primer.
https://static1.pt-content.com/images/pt/2013/11/20131116143704-1.jpg (http://s719.photobucket.com/user/dan10101/media/El%20Camino%20Build/2013-11-16143704.jpg.html)
https://static1.pt-content.com/images/pt/2013/11/20131116152958-1.jpg (http://s719.photobucket.com/user/dan10101/media/El%20Camino%20Build/2013-11-16152958.jpg.html)
Of course we prepped and painted the other body parts.
https://static1.pt-content.com/images/pt/2013/11/20131116164632-1.jpg (http://s719.photobucket.com/user/dan10101/media/El%20Camino%20Build/2013-11-16164632.jpg.html)
We still have a long way to go, found a few problem areas that were hidden with the multiple colors and other areas that we (me) just forgot. But it's great to have it one color again.
https://static1.pt-content.com/images/pt/2013/11/20131116164738-1.jpg (http://s719.photobucket.com/user/dan10101/media/El%20Camino%20Build/2013-11-16164738.jpg.html)
johnny68
11-17-2013, 09:46 PM
looking good hey Dan if you want to sell your wheels let me know im looking for anything due to the 72 camino i just got has none and im borrowing the ones on it.
john
dan10101
11-20-2013, 10:56 PM
I'll keep the wheels offer in mind. Most likely I'll be keeping them. Good luck with your elky.
dan10101
05-06-2014, 04:13 PM
Sorry for the lack of updates. I lost my Father a couple days after the last update and that just threw me for a couple months. But I got back on it and have made steady progress. The original goal for the last year was to get the truck ready for our annual Graffiti festival in June 2014. It's exactly a month from now for the parade of cars downtown. There is still a good chance to have it done by then to at least look complete.
It doesn't really look any different from the last couple of photographs that I posted but now it's a lot closer to being done. I've done a ton of blocking and sanding, and more primer, and more blocking and sanding... You get the picture. The good news is I'm planning on painting door jams and other hidden areas this week. Then we'll assemble the car and hopefully we can get into the paint booth next week to do final paint.
https://static1.pt-content.com/images/pt/2014/05/20140325175202-1.jpg (http://s719.photobucket.com/user/dan10101/media/El%20Camino%20Build/2014-03-25175202.jpg.html)
Also over the last few months, I've torn out the wiring, dash and much of the engine compartment.
Replaced the heater motor, moved the FI computer and it's massive wiring harness under the fender and out of the way making the engine compartment much cleaner. I cleaned and painted along the way.
Before
https://static1.pt-content.com/images/pt/2014/05/201402091446271-1.jpg (http://s719.photobucket.com/user/dan10101/media/El%20Camino%20Build/2014-02-09144627-1.jpg.html)
After
https://static1.pt-content.com/images/pt/2014/05/100_2533-1.jpg (http://s719.photobucket.com/user/dan10101/media/El%20Camino%20Build/100_2533.jpg.html)
I installed a new American Autowire Classic update harness which really cleaned up the project. The old harness was riddled with patches, clamp-on connectors, missing wires and added wires. I counted over 50 non stock items in the dash harness alone.
https://static1.pt-content.com/images/pt/2014/05/20140328215531-1.jpg (http://s719.photobucket.com/user/dan10101/media/El%20Camino%20Build/2014-03-28215531.jpg.html)
I removed the dash and did a custom install of aftermarket gauges in the original idiot light locations. Plus I removed the clock and installed a tach unit designed to replace the clock.
https://static1.pt-content.com/images/pt/2014/05/Dashgaugesinthesunlight-1.jpg (http://s719.photobucket.com/user/dan10101/media/El%20Camino%20Build/Dashgaugesinthesunlight.jpg.html)
After much deliberation I installed a Retrosound stereo in the factory location. Added factory style stereo speakers below the new dash topper as well as my old Realistic speakers under the back shelf. Still looking for a compact subwoofer to round off the sound a bit.
https://static1.pt-content.com/images/pt/2014/05/20140423222027-1.jpg (http://s719.photobucket.com/user/dan10101/media/El%20Camino%20Build/2014-04-23222027.jpg.html)
How it looks today. Ready to lay down some Victory Red!
<a href="http://s719.photobucket.com/user/dan10101/media/El%20Camino%20Build/100_2502.jpg.html" target="_blank"><img src="http://i719.photobucket.com/albums/ww198/dan10101/El%20Camino%20Build/100_2502.jpg" border="0" alt=" photo 100_2502.jpg"/></a>
Still a ton of things to do to get ready for June. And another ton that I expect will need to wait until after the car show season. But, it's been a labor of luv and a big learning experience. The best part is that I've been able to do most of the work myself with a little help along the way.
dan10101
05-25-2014, 09:56 PM
We have color!
https://static1.pt-content.com/images/pt/2014/05/20140526021056-1.jpeg (http://s719.photobucket.com/user/dan10101/media/El%20Camino%20Build/2014-05-26021056.jpeg.html)
I know nobody really cares about an old el camino. But it's finally looking like it should. I'm just happy to have it all in color.
https://static1.pt-content.com/images/pt/2014/05/20140526021103-1.jpeg (http://s719.photobucket.com/user/dan10101/media/El%20Camino%20Build/2014-05-26021103.jpeg.html)
dusterbd13
05-28-2014, 06:00 PM
looking good, and im jealous. someday ill have the 64 back in color.
slammedwhitec5vert
05-29-2014, 04:03 PM
Looking good I love red Elco's
zdiesel
05-30-2014, 09:36 AM
Looks sweet dude! Love these El Camino's, the red looks killer.
dan10101
06-01-2014, 10:51 PM
Thanks for the comments guys.
Here she is all decked out in jewelery. Still have the stripes to add on and a couple more nagging items, but overall, I'm calling her done for the purposes of hitting the summer car shows.
https://static1.pt-content.com/images/pt/2014/06/100_2535-1.jpg (http://s719.photobucket.com/user/dan10101/media/El%20Camino%20Build/100_2535.jpg.html)
https://static1.pt-content.com/images/pt/2014/06/100_2537-1.jpg (http://s719.photobucket.com/user/dan10101/media/El%20Camino%20Build/100_2537.jpg.html)
https://static1.pt-content.com/images/pt/2014/06/100_2538-1.jpg (http://s719.photobucket.com/user/dan10101/media/El%20Camino%20Build/100_2538.jpg.html)
https://static1.pt-content.com/images/pt/2014/06/100_2539-1.jpg (http://s719.photobucket.com/user/dan10101/media/El%20Camino%20Build/100_2539.jpg.html)
https://static1.pt-content.com/images/pt/2014/06/100_2532-1.jpg (http://s719.photobucket.com/user/dan10101/media/El%20Camino%20Build/100_2532.jpg.html)
68'PRO-ELCO
06-27-2014, 08:05 AM
That's a killer job!!! Congrats on a beautiful Elco, and a fantastic piece of Chevy history!
dan10101
06-27-2014, 08:23 AM
Thanks for the kind words. It's a far cry from some of the machines on this site, but it looks good and I'm happy I was able to do most of the work. Let's see some pictures of your Pro-Elco. I love to see what others are doing. It helps me spend money.
RodZZilla
06-28-2014, 04:15 PM
Nice Job! I love how it turned out.
dan10101
06-28-2014, 07:06 PM
Thanks, We still need to do a wet sanding and painting the hood and tailgate stripes, then some mechanical stuff underneath. But at least it looks complete for the first time since I've owned it.
Bonehead
06-28-2014, 09:44 PM
72 El Camino was my first car. Fun to see your build. Lookin good in red!
dan10101
06-28-2014, 09:58 PM
Thanks, I hope my next build is a early 60s twin turbo LSx. Love the 67 Chevelle. That or an early Nova. (no smog in Cali)
Bonehead
06-28-2014, 10:22 PM
Currently building a single turbo LS in a 67 Elk. Its been a bit of a difference between the Chevelle I did. Frame has some differences and then just the attributes of an Elk. But I'm slowing starting to get attached to it. Long way to go, but have the next round of parts ordered for it. Hoping to have it done a year from now and get it out on the road.
dan10101
06-28-2014, 10:42 PM
Looks like a great project. I'm sure I'll have more questions later.
I actually was thinking of hiding a big turbo in the smugglers bay that would feed back thru a center console and feed an innocent looking air cleaner from the back, keeping the relatively stock engine bay. Alas, I didn't have the budget for it. It will have to wait for the next project after I sell some machines.
dan10101
11-20-2014, 10:31 PM
Finally got the strips, and cut and buff complete.
It's exciting to walk out into the garage and see this beast, even more to take it on occasional errands.
105507
105508
