View Full Version : c-5 z06 front and rear brake part #'s
brownz
05-17-2007, 02:57 PM
hi this is my first post and have been reading on this site for some time, would just like to say thanks for all the great info. and now for the question i have a 79z, i work for a chevy dealer and can get all the parts at discount so would like to know if anyone has all the part numbers for c-5 z06 front calipers,brackets, slid pins and for the rear the calipers, bracket ( 2 left side) and all e-brake hardware needed and any helpful tips needed for the swap. and i do know of kore3 but for the money would think that i could get the parts from work and save $ and get the rest from kore3.
eville
05-17-2007, 09:21 PM
I previously posted the regular c5 part numbers here...
https://www.pro-touring.com/forum/showthread.php?t=28569&highlight=numbers
Someone can correct me if I'm wrong, but IIRC the diff. between C5 and C5 Z06 was color of the caliper.
If you're talking C6 zo6, search parts at gmpartsdirect by typing c6 in the search field.
http://www.gmpartsdirect.com/
hardline_42
05-18-2007, 04:46 AM
The abutment brackets will be the same part number left and right. If you're keeping the staggered shock setup, you'll need two of the same caliper so the bleeder is on the top on both sides. Just make sure to mount the conversion brackets (Kore 3) on either side facing opposite directions.
As far as an e-brake option, the only one I know of is the Kore 3 setup (I ran my setup without an -brake). The only GM part that can be sourced is the drum backing plate IIRC.
brownz
05-21-2007, 03:34 PM
thanks for all the info but all i need is the parts numbers for all the parts listed ( gm part numbers) thanks
05-21-2007, 07:25 PM
I believe Eville did, all you had to do was search C5 Zo6 and scroll down...but to be quite honest you would be better off buying the set from here. By the time you peice together a kit from GM you would be spending more, even with your discount. Caliper alone at cost is $115. http://www.engineeredvelocity.com/
For the rear use a 98-2002 Camaro set up.
brownz
05-22-2007, 03:46 PM
thanks for the new site will check them out
