View Full Version : Do I need to
Bow Tie 67
05-17-2007, 05:10 AM
add a loop in the brake lines from the master cylinder to the front and rear brakes? I believe the loops where there originally for chassis flex. My car has a chassisworks front subframe with solid mounts and welded in rear subframe connectors. I'll be using ss lines and was thinking I can get by without making loops. Or is it better safe than sorry as the master may also flex slightly when the brakes are applied.
HILROD
05-17-2007, 05:41 AM
The loops don't have to be there but you need enough to let them flex a bit. With the solid mounts all you'll have is firewall flex, and vibration. I've got a bunch of different tubing benders if you need them.
CarlC
05-17-2007, 08:02 AM
Try to put in some kind of bend to allow for flex. Mine have a 90* after exiting the MC and then a small bend before attaching to a "T" near the LH wheel.
The original loops also allow for booster removal without MC line disconnect.
NOT A TA
05-17-2007, 07:09 PM
I usually roll a couple loops around a thick broom handle to be safe. Cars flex and vibrate nevermind the twisting from engine torque and hard cornering. Don't want to be in the pits fabbing a new brake line instead of running around the track!
John
