View Full Version : Minilite/Panasport/TeamIII
smhigh
05-16-2007, 07:51 PM
Looking for 15x8 15x7 minilite type wheels for 68 Camaro....
Going for old school look and going to run Goodyear Blue Streaks
Damn True
05-16-2007, 08:02 PM
Well if you are going to run 15's I suggest the panasports or minilites they are both closer to the original look than the Team III wheel.
chicane67
05-16-2007, 08:07 PM
Vintage Wheel also makes a nice 16, 17 and soon to be an 18" of the same wheel.
Damn True
05-16-2007, 08:14 PM
The VWW unit looks good in the photos, but up close the spokes are shaped all wrong. If he is going for an authentic look, which I assume he is since he's planning on running a 15 incher I think the minilite or panasport would look closer to the real deal of old.
70RT/SE
05-17-2007, 03:46 PM
If you have the budget I would go with the real Minilites. I don't think there is a U.S distributor any longer. It used to be Main Street Motorsports but he stopped importing them....don't know if someone else is going to pick them up. When I inquired about them last year they were over $300 per wheel for a 15x8.
Superlite also makes the same style wheel. I have the Team 3 wheels on my car but they are 17s.
Damn True
05-18-2007, 07:23 AM
If you grab a copy of Grassroots Motorsports there are a couple of ads for Minilite importers.
smhigh
05-21-2007, 06:27 PM
What about the American Racing Silverstone
http://www.newstalgiawheel.com/wheel_detail.asp?subcat3=1011112
Has anyone seen these and are they close to the minilite spokes.....I don't like the look of the VWW
Thanks for your thoughts
Damn True
05-21-2007, 08:45 PM
That is pretty accurate, a lot more so than the VWW version.
The Silverstone
Here is the panasport.
If you look at the VWW, the spokes are much more angular and the center hub has square edges as opposed to the more correct rounded edges.
Here is the VWW wheel. It's not an altogether bad looking wheel. But it is not a very good replica of the real thing.
wendell
05-22-2007, 05:30 AM
The panasports are going to give you the most authentic look. The center sections on the modern minilites are too big. Regardless of looks the Panasports were always favored in T/A because they're lighter. The wheels on the SVRA car I support are 15X8" with about 4.5" of back spacing. It takes a 1/4 spacer to clear the J-56s (JL-8?). Interestingly eventhough there's clearance a 8.5" hoosier causes enough flex for the caliper to rub the paint off the wheel.
