View Full Version : Need Rollbar for 68 Camaro
tumper93
05-14-2007, 11:25 AM
I am looking for a rollbar that will fit a 68 Camaro with a factory interior except for 4th gen camaro seats. I need it to allow the rear seat to be installed, not used by passengers, and factory headliner.
jason@gmachine
05-14-2007, 12:10 PM
custom, a good fabricator will be able to meet all those requirements and make it plenty strong for safety reasons. im finishing a 6pt cusotom roll bar and I will post up pics later today. It does eliminate the rear seat but minor adjustments to the rear bars and the seat can be saved.
Jason
jason@gmachine
05-15-2007, 02:03 PM
here is the custom setup i was talking about.
Here is the thread to more pics.
https://www.pro-touring.com/forum/showthread.php?t=30595
Jason
tumper93
05-16-2007, 07:31 AM
Thanks Jason that gives me the ideas I need. I would rather do once then to have to go back and redo something cause I didn't like the fit. Many thanks
jason@gmachine
05-16-2007, 01:58 PM
no worries, check out this idea. Its a removable section of the harness bar, if can also be made to have the entire harness bar removable.
Jason
DeepBlue68
05-31-2007, 07:02 PM
You should check out the DS&E rollbar (link below). I bought it through YearOne when they first started offering it and got it for like 20 or 25% off (which was a heck of a deal); not sure if they run specials on it anymore though. It has a removable harness bar, and as far as I know, it works with the factory interior. It hasn't been installed yet so I can't comment on the quality or ease of installation, but I've heard good things about it.
Link is Here (http://www.detroitspeed.com/productpages/indproduct/bodyprod/roll_cage_prod.htm)
Off Topic: Jason, very nice work on the cage you guys did; I bet that thing is rock solid. One thing I was wondering - what was the reason for not leaving fillets on the main 90s on the bracket welded onto the tube in the last picture? I guess if you did that you'd also have to radius the piece that it meets up with, which means more fabrication time. Just curious....really nice work
jason@gmachine
06-01-2007, 01:10 PM
Im not quite sure what you are asking?
but alot of the style is from the customer. He wanted this sort of "flow" to it. Please refrase your question so i can give the proper answer.
Jason
DeepBlue68
06-04-2007, 05:18 PM
Jason - sorry for the confusion; I was thinking that you actually fab'd the male/female quick-disconnect brackets that are welded onto the ends of the harness bar and the pieces of the cage that it meets up with. I was asking a question about why you designed those brackets the way you did, but now I realize you didn't design them. Or did you? Maybe I've confused everyone including myself :hand:
jason@gmachine
06-04-2007, 07:21 PM
we did not make them, we get them machined and with the bolts already. They are from the off-road race world and i think they are the only option for any sort of removable bar in a setup like this.
No worries, Jason
