View Full Version : can anybody redrill hubs/axles to different lug pattern ?
TRILOGYZ28
05-12-2007, 04:42 PM
i am looking to change lug pattern on my 01 2wd s10 blazer. does anybody know where i can get this done and how much?
and will/can it be accurate ?
i can provide a set of rear axles and front hub assemblies.
jerome
05-12-2007, 06:08 PM
I think you need to drill rotors also. I am looking into this too, because I just bought a ford 8.8 for my s10, and it has 5x4.5 bolt pattern.
Jerome
TRILOGYZ28
05-12-2007, 06:17 PM
Jerome
the rotors are all slip on, i can easily have those re-drilled, but i want the axles and hubs accurate.
Texas Hotrod
05-12-2007, 07:38 PM
I converted some Ford axles to a Chevy pattern.
The Ford wheel register was slightly bigger than the Chevy's, it had to be turned down in/a lathe.
I used an IROC brake rotor as a template, used a 1/2" dowel punch to mark the stud centers and drilled the new pattern in a drill press.
My wheels bolted up fine and rolled true.
Drilling brkae discs? That might be tricky, something I've never done.
Any reputable machine shop should be able to do it.
05-12-2007, 08:58 PM
Thats how I do it...WHATS THIS???the king of spot weld ownage can't drill 10 holes????? Just kidding. Good punch, good bit , easy going on the drill press and lots of time.
If you have to machine the hub hole, do that first at a machine shop. Or buy a lathe.
TRILOGYZ28
05-13-2007, 07:48 AM
haha !
i could probably do it, but i don't feel that i can get it dead accurate.
i wonder if Moser or Strange can redrill axles and hubs?
