View Full Version : unisteer big block chev steering shaft kit HELP
copo69
05-07-2007, 02:44 PM
Anyone Running The Unisteer Power Rack And Pinion Kit On A First Gen With The Big Block 3 U Joint Steering Kit. ? Need Some Pic,s Please Of This Set Up. Following The Instructions And Nothing Is Lining Up Shafts Are Way To Long One Is 14 Inches Length One Is 7 Inches Length. Need To See Some Pic,s Fast To Get This Finished . Thanks
EFI69Cam
05-07-2007, 04:04 PM
I would love to see installed pictures as well.
NovaPwr
05-07-2007, 05:27 PM
You have to cut them to the proper length. I used wood dowel rods to mock it up. I only have the two pc and a small block but the dowels helped me to cut metal only once. Good luck with it.
ls427ss
05-07-2007, 09:32 PM
I believe you need to cut them the length you need to fit "your application" as appropriate.
The shafts are too long so they can be installed in different configurations, positions, and for needed header clearance.
If you cut them too short, you might as well cut them twice more...
I cut it three times, and it was STILL too short...
