LowBuckX
05-06-2007, 09:13 PM
Swapping to the TC pump is very costly IMHO. If I didnt get the custom pump for free I wouldnt be doing it at all. So to save a bit I decided to make a braket saving $75-$150. I will be using a KRC tank and aqx hoses.
The Aluminum Im using is another scrap pile special I scavenged at my old job from a Machine table they had made and had to trim this section. It is 5/8 thick. I dont know the grade Al but it is very hard for AL and was fairly hard to drill.(again hard for AL).
Anyway Ive seen alot of Face mount type brackets so to keep it simple I did the same with face mount.
Its not done yet. I have to machine the Adjuster grooves in it and get a shorter belt so it is mounted closer inboard. I will be using all 3 mounting bosses with 5/16 hardware. I retaped the 8MM to use 5/16 also. The adjustment will be linear and not eccentric so that may be interesting to get it tight but shouldnt be hard at all.
Luckily the 5/8 is perfect for belt alignment. What do you think.
