View Full Version : How to tell if a 1970 Chevy is numbers matching?
moparguy
05-06-2007, 02:51 AM
I have just purchased a 1970 Impala 454 and I am wanting to know how I can tell if the engine is the original engine for the car???
Is the VIN stamped on the block anywhere???
TT402LS1
05-06-2007, 04:45 AM
I believe it is on the engine block head surface on the passengers front. It is a stamping not a casting.
Ron
ProdigyCustoms
05-06-2007, 05:17 AM
Yep, stamped right in front of the passenger cylinder head in the block deck. Gotta look behind and under the alternator. Also, if it is a original 70 motor the casting number on the bellhousing flange behind the drivers side cylinder head is cast into the block and should end in 512.
dhardison
05-06-2007, 06:41 AM
Is the VIN stamped on the block anywhere???http://www.mortec.com/location.htm
http://www.mortec.com/bbc.htm
