View Full Version : Disc/disc vs. Disc/drum Masters
68Formula
04-30-2007, 11:50 PM
What is the difference between a 4 wheel disc Master and a Front Disc master only?
I read in some places it's not necessary to change over as long as you have an adjustable pressure valve and others say it needs to be done.
I switched from 4-wheel drum to front disc already. I have the Baer Track discs, their master, and a stock 13" booster. I used an adjustable prop valve.
Now I have a rearend that came with LT1 rear discs setup already installed.
Thanks.
NovaPwr
05-01-2007, 04:09 AM
http://www.mpbrakes.com/technical-support/reference-master-cylinders.cfm
This may help answer your questions.
68Formula
05-01-2007, 10:59 AM
Thanks. I checked it out and another link in the Brakes section.
I just called Baer (since it was their master I used) and they said the MC supplied is designed to work with the exact rear calipers I have anyway. And since I was already using the prop valve, there is nothing to change. Very good news.
