View Full Version : Question on suspension options with a big brake kit...
sunset68
04-29-2007, 02:19 PM
I have a wilwood 6 piston brake kit for a 67-69 camaro. I was wondering if the stock spindle is the only option for using this kit. I know I can't use an AFX C5\C6 spindle, but how about a drop spindle? Does anyone know of an option that may give me better geometry? I currently have stock spindles with BMR UCA's and LCA's, QA1 coilovers. Is there any spindle option out there that will add much my current set up? Thanks in advance for any help\advice you can lend me.
Chris.
TBART70
04-30-2007, 04:08 PM
Hi Chris, I wonder where your getting those brakes from? You might want to call Mark @ SC&C, he may be able to sell you a tall ball joint to help the camber gain. I do not know how tall they can go, Mark will have an answer. Heidt's makes a tall spindle, 2" drop uses factory brakes, but the bumpsteer has not been corrected ( someone elses words ). You may be able to adjust the bumpsteer on the Heidt's with a kit, I'm not sure how far they would have to go but maybe it would be possible. Good luck and thanks again.
(this should be in the suspension forum)
http://www.scandc.com/
