View Full Version : 1971 Chevelle twin turbo (pics)
TT402LS1
04-27-2007, 06:46 AM
Here are some pics of my progress..
https://static1.pt-content.com/images/pt/2007/04/S5000215-1.jpg
https://static1.pt-content.com/images/pt/2007/04/S5000213-1.jpg
https://static1.pt-content.com/images/pt/2007/04/S5000165-1.jpg:6gears:
Ron
camcojb
04-27-2007, 06:52 AM
Slick setup Ron. I also have a twin turbo 402 going in my 64 Chevelle. I don't have the tig skills at this point, so I'm using some Nelson Racing headers. He's re-doing the headers right now, should have them back in a week or two.
Nice work. :twothumbs
Jody
Samckitt
04-27-2007, 08:44 AM
Beautiful is all I can say. Keep us posted.
Looks good. What kind of fuel injection are you going to be using?
whytry
04-27-2007, 09:39 AM
That's awesome!!!
shmoov69
04-27-2007, 08:10 PM
sweeeet!
marxcamaro
04-27-2007, 09:49 PM
Great job! I like the unique area that you placed them. Very tidy look!
sweeeet!
TT402LS1
04-28-2007, 05:04 AM
Thanks! I will be running an Edelbrock Victor Jr EFI manifold with a FAST 4 bbl TB. It will all be tune on a friends of mine 901 Super Flow dyno using Big Stuff 3.
Ron
Blown353
04-28-2007, 07:48 AM
Ron,
Have you considered going with an elbow and a monoblade TB?
I've done a couple boosted cars and the monoblade/elbow setups have better mixture distrubution and throttle response than the 4-hole TB's. I'm doing another monoblade/elbow/Vic EFI right now actually on a Ford.
The 4-holes work well on naturally aspirated cars and work pretty good on boosted applications but the elbow/monoblade setup really shines on a boosted engine.
camcojb
04-28-2007, 08:13 AM
Ron,
exactly what happened when I went from 4 hole to monoblade, better throttle response and a much better look in my opinion.
https://static1.pt-content.com/images/pt/2006/09/zl1motor3-1.jpg
TT402LS1
04-28-2007, 10:11 AM
I guess I never gave it any thought. I thought people only used the elbow in Camaro/Firebirds due to the lack of hood clearance. I was gonna use a 1300cfm Fast TB. Would a 90mm flow as good with an albow? Who makes nice looking elbows??
And what about the throttle braket? Can you buy them or does it come with the elbows? I do like your set-up Camcojb!
Thanks - Ron
camcojb
04-28-2007, 11:31 AM
Thanks - Ron
I made that bracket myself. You're kinda on your own for that.
Jody
TT402LS1
04-28-2007, 11:50 AM
Jody
Very nice! If I decide to go that route, will you be interested in making another one??
Ron
64duece
04-29-2007, 03:22 AM
ditto on the elbow/monoblade. Wilson/Accufab are a nice combination. Precsion also offers a nice elbow at a reasonable price.
Tokyo Torquer
04-29-2007, 06:33 AM
wow..that is beautiful.. a very clean set up. I have always been a big roots blower person, but I am starting to feel the lure of turbos.
Blown353
04-29-2007, 06:40 AM
The Wilson cast elbow is nice and matches a cast intake very well. You can also do a sheetmetal elbow, that's what I'm using on the Ford I'm working on, but in all honesty I like the more "uniform" look of the Wilson cast piece on a cast single plane.
The monoblades flow a LOT of air. Don't go too large though or things can get really touchy at low-rpm and off-idle unless you come up with a progressive cable cam. Barely opening a large monoblade results in a huge change in airflow and makes the engine really touchy just off idle. A smaller monoblade will be "softer" and easier to modulate at low RPM.
If you are using 3" intake piping on your boost side (which is pretty standard) a 75mm monoblade will flow plenty as it is only 1.6mm smaller in ID than the 3" intake piping. Once at WOT the edge of the butterfly and cross-shaft presents only a minimal restriction and really isn't a concern. I run a 75mm on my car and throttle response is fantastic without being too touchy in the "off-idle" ranges.
Being that you'll be feeding 402CI I'd suggest a 75 or 80mm TB. 90mm or bigger will be really touchy off-idle unless you have a progressive linkage that is biased to be very "lazy" in the lower throttle position areas and I don't think you'll see any difference in power with anything bigger than an 80mm. Now if you were running naturally aspirated with more cubes a bigger TB would certainly be worth a look, but that isn't the case here.
705.0Merc
04-29-2007, 06:32 PM
Looks great! Turbos are the way to go, especially on a heavy car. It sure works good on mine.
LS1NOVA
04-30-2007, 08:52 AM
check out Intakeelbows.com also. I am very happy with his work.
