View Full Version : Carbon Fiber Accents
Modo Innovations
04-23-2007, 06:32 PM
How many of you are going to use or are using carbon fiber to accent the interior?
WEAVER
04-26-2007, 06:42 PM
We use it a lot for fabrication to get the strengh we need,and also for looks in diffrent places.Stronger than fiberglass
smittys69
04-26-2007, 06:52 PM
I did it in mine. I used the covan's dash and also purchased some peel-n-stick matching carbon fiber and covered the removable plates on my console. Matches up with the dash very nicely and doesn't look half assed.
bobbaganoosh
05-04-2007, 03:50 PM
I made my gauge cluster out of carbon fiber. I took the original one and cut a sheet of cf to fit then epoxied it together. Then I cut out the gauge holes and put a couple coats of clear over the whole thing. I'm also making a pass. side dash trim piece as well as a console piece to hold other gauges and a boost controller.
Samckitt
05-04-2007, 03:59 PM
Looks great. I want to do that with the Monte gauge plate & the trim piece in front of the passenger, as well as the console. Which gauges are those? Where did you get the fabric, & what is the clear you use? Is it made special for CF or is it a varnish like stuff you can get anywhere?
bobbaganoosh
05-04-2007, 05:05 PM
Thanks, they are Auto Meter ultralights. The carbon fiber was already a cured sheet, I just sanded it with 600 grit and sprayed it with an automotive clear. I got it off of ebay, it looked like some parts were cut out of it with a water jet or something but there was enough to do the job. The turn signals/ high beam indicator are led's, the bezels came from radio shack. They were chrome but I blasted them and painted them silver.
Damn True
05-05-2007, 09:57 AM
I plan to use it in the console, dash and maybe even some door panels.
