View Full Version : Removing water spots from aluminum
smittys69
04-22-2007, 08:33 PM
Got some water spots on my polished aluminum valve covers when my lower radiator hose decided to let go. Now I can't seem to remove the spots / stains from the valve covers. I have tried aluminum polish and even tried a small power ball and not much luck. Anyone have any ideas? Am I going to have to pull them and polish the hell out of them to get the spots removed? Thanks
69TAPoser
04-23-2007, 04:43 AM
Have you tried this yet...?
I am a big fan of Nevr-Dull. I have used it for years on aluminum parts. It is cheap, but does require a bit of "elbow grease." If you work it good, it will give you a mirror shine.
Phil
Steve68
04-23-2007, 05:37 AM
Simichrome or similar pastes
BADVELLE
04-23-2007, 06:18 AM
Phil
I 2nd this one, great stuff, relatively low elbow grease factor!
Restomod
04-23-2007, 03:44 PM
I never got good results with anything but Mothers aluminum polish for getting water spots off.
smittys69
04-23-2007, 06:08 PM
Thanks guys - I'll try these out.
shmoov69
04-23-2007, 06:49 PM
The best luck I had was to spray etching wheel cleaner on them and start over! Mine still have water spots on them since I don't want to go thru that again! Good luck!
69muscle
04-23-2007, 08:00 PM
00 or 000 steel wool try a small area first, works on aluminum rims, really depends on the quality of aluminum.
ProTouring442
04-24-2007, 03:29 AM
Vinegar... but clean it off quickly. Water spots are usually calcium deposits, and the acidity of vinegar will remove them.
Shiny Side Up!
Bill
'72 442 "Inamorata"
'89 ASC/McLaren
www.FQuick.com/ProTouring442
83hurstguy
04-24-2007, 05:28 AM
Mother's Billet aluminum polish... its not cheap, but it works real well.
mpozzi
04-27-2007, 09:40 AM
Got the same question but for glass . . . ??
Cheers,
Mary Pozzi
83hurstguy
04-27-2007, 12:10 PM
Cheers,
Mary Pozzi
the windows in my Hurst are acid rain etched with spots all over... nothing I have tried so far has taken them out, I think I even tried some car compound at one point.
I bought Eastwood's glass polishing kit, but haven't tried it yet. That turns into a messy project real fast.
Jims78elky
04-27-2007, 12:40 PM
I thought that you could also use a "clay-bar" to remove the
water spots? I'll have to try a little spot on my side window.
Testing...Testing.......Testing!
:idea:
-Jim
ProTouring442
04-28-2007, 02:50 AM
Cheers,
Mary Pozzi
I had great luck with CLR and bronze wool. Not a great idea if the windows are in the car though as CLR is an acid. I soaked them for a while, then scrubbed with the bronze wool. I think I did this 2 or 3 times per window, and pretty much all of the spots came off.
Shiny Side Up!
Bill
'72 442 "Inamorata"
'89 ASC/McLaren
CraigMBA
04-28-2007, 11:43 AM
Mothers Chrome Polish.
On the bottle "safe for glass and mirrors".
DO NOT USE MAG AND ALUMINUM POLISH.
In a pinch 0000 steel wool.
wedgehead
04-30-2007, 10:09 AM
I use a product called White Diamond milti-porpose metal polish. This stuff is the best polish I have ever used and I have used them all. It will really shine up that polished aluminum. You can get it at their website whitediamondpolish.com
silver69camaro
05-02-2007, 08:38 AM
I just use chrome polish on windows for water spots. Always works for me, and gets them REALLY clean. I'd be wary if they're tinted, though.
EFI69Cam
05-02-2007, 09:38 AM
try Bon Ami cleaner for glass. I have have had great success with it. Best to try in a inconspicous spot first.
