View Full Version : G Brace Re enforcements
Jeremy
04-21-2007, 10:49 AM
Here are some pics of my g brace mods. My goal was to take some of the load off the cowl. The car is significantly stiffer and much more responsive with the extra support.
The passenger side.
https://static1.pt-content.com/images/noimg.gif (http://img264.imageshack.us/my.php?image=p1010016ea7.jpg)
The driver side.
https://static1.pt-content.com/images/noimg.gif (http://img292.imageshack.us/my.php?image=p1010015zu6.jpg)
A close up of how the bars converge at the top to make a true triangle.
https://static1.pt-content.com/images/noimg.gif (http://img292.imageshack.us/my.php?image=p1010017zg9.jpg)
Some close ups showing the clearance around the air cleaner and shaker.
https://static1.pt-content.com/images/noimg.gif (http://img264.imageshack.us/my.php?image=p1010018hv2.jpg)
https://static1.pt-content.com/images/noimg.gif (http://img264.imageshack.us/my.php?image=p1010019kg8.jpg)
https://static1.pt-content.com/images/noimg.gif (http://img292.imageshack.us/my.php?image=p1010020js4.jpg)
I still need to do some finish work before paint. I need to cut all the bars at angles to match the g braces and box the ends of the tubes.
formula
04-21-2007, 03:31 PM
slick idea...i'd been thinking of doing something similar on my car, but slightly different in location. yours may be smarter. :twothumbs
parsonsj
04-21-2007, 03:43 PM
I would weld through-tubes into the cage and brace so that the bolts don't crush them. Otherwise, you'll have trouble keeping the bolts tight.
jp
Jeremy
04-21-2007, 05:01 PM
Good idea. I have been running some sort of brace across the g braces for over a year and crushing them I don't think is possible. I've broken bolts before I could crush the braces.
The square stock is another story. They 1 x 2 has started to crush a bit and that along with asthetics was why I was going to box the ends. Do you think that will be enough or should I put tubes in there? The bolts are about 1/2 inch from the ends.
parsonsj
04-21-2007, 05:24 PM
I always put through-tubes in for bolts. It is more important than boxing the ends. It will prevent crush and provide a flat mating surface too.
No doubt the boxed end will help, but a through tube is a permanent and secure fix.
jp
Jeremy
04-21-2007, 07:05 PM
Thanks. It is easier to do it now than wish I had down the road.
