View Full Version : Best sub frame connectors for 67 Camaro
TEG67RSSS
04-19-2007, 12:34 PM
Looking for thoughts on the best subframe connectors for a 67 Camaro!
Anybody using the Global West connectors?
6'9"Witha69
04-19-2007, 12:37 PM
I have the GW ones. Not installed yet but will be. If you can do it or know someone who can and don't mind cutting up your floor then the DSE ones are probably better as they tie the floor in. I want to leave my floor alone so it is GW for me.
Remember that the best ones will be weld in and that requires solid subframe mounting bushings.
TEG67RSSS
04-19-2007, 12:42 PM
Thanks, I have the GW body mount kit already, Thinking about using the GW connectors also.
Lowend
04-19-2007, 12:53 PM
The GW SFC's are the best I have found where you don't have to cut up the floor pan.
