View Full Version : 4l80E in a nova...??
novaracer
04-15-2007, 05:42 AM
I have a 68 nova that I am putting a 4l80e in I have the transmission (built by finish line w/rossler brake) I also have Big stuff 3 w/transmission control what else will I need to change? ( has old style 408SB not LS style )
Crossmember....will be custom made to fit
drive shaft (need to be shorter)
shifter (4 sp)
new lines (will be made)
what about the flex plate will my current one work? I have a th400 in the car now...
Did I miss any thing else? I would like to have every thing before starting so I have less down time.
thanks BC
Steve Chryssos
04-16-2007, 10:07 AM
Flxplate should be fine. Converter bolts will change to metric. Also Russell makes a great fitting that saves some space to the trans tunnel. Part Number 612000
DeltaT
04-17-2007, 08:21 PM
You didn't mention converter but I'm sure you already know it's different. If you are running a transbrake you should tell the converter shop what you are doing.
Lokar makes a nice cable kit to go between most shifters and the 80E. Very good quality.
Tranny mount may need to be higher than the TH400.
I like the ARP converter bolts. There's only 3.
Hughes makes a really nice quality deep sump pan with a drain plug.
Redline Oil's Racing Transmission Fluid is a full synthetic Type F fluid, if Carl says a synthetic is OK with his tranny. With the deep sump pan mine took 13 quarts without a cooler on it before it was correctly filled!
B&M makes a nice brazed-plate-style SuperCooler that's more efficient than the typical tube and fin unit.
Do you already have a 168-tooth flexplate in the 400?
Finally, Lokar also makes a nice dipstick that mounts either on the engine or the firewall.
HTH,
Jim
novaracer
04-21-2007, 05:57 AM
thanks guys
ponjohn
04-22-2007, 04:45 PM
Is it actually in? The circumference of the 80e is much bigger and you may need to maasage the trasn tunnel to get it to fit.
DeltaT
04-22-2007, 05:59 PM
I only had to massage the floor a liitle bit to accomodate the speedo cable attaching further back, like a 4"L x 3/4"D trough. Since I retained the stock column shifter, I have to lengthen and offset back the linkage retainer to work smoothly.
I never downshift manually lower than D, so I don't miss it, but the full-length headers conflict with the tranny linkage so I can not downshift manually to 2 or 1. I think you'd have to get rid of the column shift.
Jim
