View Full Version : PCV valve needed?
73ta
04-08-2007, 11:56 AM
Help me understand why I would run a PCV valve. I would think that you would not want to disturb a properly setup carb with a vacuum leak with blow by fumes, unless you had to for smog. I could never get my system to work with a PCV valve no matter where it was mounted or how it was baffled. Always used oil with it. Have been running for 4 years now with just vented to the atmosphere valve covers. No oil usage and no oil leaks. Any thoughts?
Adam's 55 Chevy
04-10-2007, 01:32 AM
EPA. If you dont need one to be legal don't run one. If you do run one on that 'day'.
6'9"Witha69
04-10-2007, 08:18 AM
If you are driving around town then use it. I have seen many issues arise without them. It is like a low buck vacuum setup. They do work.
68sixspeed
04-10-2007, 04:16 PM
yep, I ended up putting one on my latest motor- without it I was getting some oil out of the breathers. I will have to try a highway run without- I never thought of it from an oil usage standpoint.
