View Full Version : Rag joint swap .
osdmike
04-06-2007, 02:59 PM
Hi!
I read a post about changing the original rag joint to a universal joint , when You lower the body over the subframe.
What do I need to make it fit ?
Is there a universal joint that will fit the original steering column ?
Found this thread.
" https://www.pro-touring.com/forum/showthread.php?t=24942&highlight=coupler "
What is a DD shaft?
Anyone got pictures ?
Partnumbers ?
"Osdmike" :dunno:
ProdigyCustoms
04-06-2007, 05:49 PM
We can set you up with a conversion joint. Manual or Power steering? BTW, a double D shaft is the intermeidiate shaft on a front steer car. You do not have one in your Camaro.
osdmike
04-06-2007, 06:45 PM
I have original Power steering.
Do I have to modify the steering column at all,...or is it bolt on ?
Pics?
Price?
Osdmike
Samckitt
04-06-2007, 06:47 PM
I would like one too for an 86 Monte with power steering.
Rybar
04-07-2007, 03:38 PM
Just did this on my car, for different reasons (I needed header clearance) try www.borgeson.com (http://www.borgeson.com) or www.flamingriver.com (http://www.flamingriver.com) you'll have to measure for the correct size. Mine ended up being 1"-48 spline (stock tilt column) and 13/16" - 36 spline (steering box end)
Here's a pic:
https://static1.pt-content.com/images/pt/2007/04/CopyofPicture029-1.jpg
osdmike
04-09-2007, 03:07 PM
Thanks for the picture ! That explains a lot.
There is no splined shaft coming out at the bottom ,where the rag joint is attached.(see pic.)
I dont know if this is the original column.
I also looked at two other Camaros (-68 and-69)
The -69 column looked like "Rybar´s" .
The -68 had a big hex nut , where the r-joint is attached.:hmm:
So here we have three different steering columns for 1st. gen. Camaro.
I guess I have to find an other steering column , with a splined shaft.
That will solve My problem.
"Osdmike" :hammer:
Rybar
04-09-2007, 09:24 PM
Mike, e-mail that pic to the tech guys at Borgeson or Flaming River, they should know what you have there.
osdmike
04-10-2007, 12:17 AM
OK ! Thanks.
"Osdmike"
osdmike
08-27-2007, 02:15 PM
Yeah!
Got a Nova -77 tilt steering column !
Flaming River 1"-48 / 13/16"-36 spline Universal Joint.
Works great !
"Osdmike"
Rybar
08-27-2007, 02:40 PM
Great news, it was a big pain for me to figure out the correct size, I'm really glad I could help you out.
