View Full Version : 70 mustang subframe/floorpan install (56k Warning)
BlackGMC
04-06-2007, 12:06 PM
Well I have been working on building my subframe for a couple of months now and today I fianlly started addin in the driveshaft tunnel. The plan is to make all the floorpans myself. Let me know what you think. Granted I have a lot of grinding ahead of me..... This is my first time attempting anything like this, so be gentle, but if you see something wrong let me know.
Begining. I got the car completely level, which was pretty tough, surprising it is totaly square...
https://static1.pt-content.com/images/pt/2007/02/2-1.jpg
https://static1.pt-content.com/images/pt/2007/02/5-2.jpg
https://static1.pt-content.com/images/pt/2007/02/6-2.jpg
Rear crossmember added so I can tie into the rear subframe and rear leaf spring mount
https://static1.pt-content.com/images/pt/2007/03/16-1.jpg
Rear Seat pans (I bought these, but I made the tunnel)
https://static1.pt-content.com/images/pt/2007/03/26-1.jpg
https://static1.pt-content.com/images/pt/2007/04/29-1.jpg
https://static1.pt-content.com/images/pt/2007/04/34-1.jpg
https://static1.pt-content.com/images/pt/2007/04/35-1.jpg
Subframe to rocker/tunnel connectors.
https://static1.pt-content.com/images/pt/2007/04/39-1.jpg
https://static1.pt-content.com/images/pt/2007/04/42-1.jpg
https://static1.pt-content.com/images/pt/2007/04/45-1.jpg
First piece of the tunnel installed. Since I don't have any clecos I used self-tapping sheetmetal screws. They will be remove and welded up once everything is finished.
https://static1.pt-content.com/images/pt/2007/04/49-1.jpg
BlackGMC
04-06-2007, 01:26 PM
I tried out the bead roller today. One tip if anyone is planning on ever using one of these, start out at a shallow depth then progressively make the bead deeper, using multiple passes, especially on 18 gauge. Other wise the bead does not turn out straight.
Bead Roller
https://static1.pt-content.com/images/pt/2007/04/50-1.jpg
https://static1.pt-content.com/images/pt/2007/04/51-1.jpg
Installed, not bad for the first time rolling beads...
https://static1.pt-content.com/images/pt/2007/04/52-1.jpg
BlackGMC
04-08-2007, 10:07 AM
Well I got another section of the tunnel done today. I am getting better at rolling beads, but like everything else, it takes practice. Good thing these will never show cause the beads are less than perfect, but it is starting to resemble a car again.
https://static1.pt-content.com/images/pt/2007/04/54-1.jpg
https://static1.pt-content.com/images/pt/2007/04/53-1.jpg
Camaro Zach
04-08-2007, 12:30 PM
Floor is coming along well.
Do yourself a favor and build a new frame for that bead roller. Also get someone to give you a hand when you are rolling the beads. Have them turn the crank while you are guiding the piece. it'l help with the straightness. I usually get my mom to give me a hand haha. Here is my *HF* bead roller.
BlackGMC
04-08-2007, 01:58 PM
Very nice, yep everyone on other sites say I need to beef up the HF bead roller, well I guess I am going to go buy more steel. Thanks for the pic.
BlackGMC
04-13-2007, 03:44 PM
I finished beefing up the HF bead roller, it rolls alot better now...
https://static1.pt-content.com/images/pt/2007/04/tool1-1.jpg
The beads in this last panel, look so much better, kinda makes me want to redo the others..
https://static1.pt-content.com/images/pt/2007/04/55-1.jpg
David Sloan
04-21-2007, 10:54 AM
Looking Good keep us posted
Quote
Current Status ChemoTherapy for the Cancer (Rust)...
This is good i got a laugh out it
BlackGMC
04-24-2007, 03:04 PM
Well I got tired of looking at the bad beads so I redid the two back panels and added a few more beads to the front one. I started working on the seat risers/pan you can see in the pic, kinda went nuts with the bead rolling thou...
https://static1.pt-content.com/images/pt/2007/04/59-1.jpg
6'9"Witha69
04-24-2007, 04:28 PM
Looks good. And I don't think the beads are too excessive. Not enough would be an issue. But yours are fine.
BlackGMC
05-03-2007, 07:34 PM
Well I had some free time so I decided to go ahead and make the rear floor board. It turned out pretty good, except the sheet distorted quite a bit while I was rolling all those damn beads. But I was able to get it straighten out. Oh and that piece of angle iron screwed to the sheet is just temporay until I can weld the floor in. Oh and I made another piece to connect the seat pan to the tunnel.
Oh and you gotta love all that flash rust!! It is easy to take off, but man it looks bad in this pic.
https://static1.pt-content.com/images/pt/2007/05/63-1.jpg
https://static1.pt-content.com/images/pt/2007/05/62-1.jpg
muthstryker
05-05-2007, 09:34 AM
man i wish i could do my own work. looks good so far, but one question. what do the beads, do? im new to most of this so i really dont know.
BlackGMC
05-05-2007, 01:11 PM
They help strengthen a panel. Basically keeps it from deflecting or bending.
BlackGMC
05-15-2007, 05:48 AM
Recent work, I made a place to mount the main hoop and added another peice to help transition from the crossmember to the tunnel.
https://static1.pt-content.com/images/pt/2007/05/64-1.jpg
https://static1.pt-content.com/images/pt/2007/05/66-1.jpg
aussiebj
05-15-2007, 06:08 AM
Where did you get that bead roller from...Nice work
BlackGMC
05-15-2007, 06:17 AM
It is a harbour freight bead roller, I got it on sale for like $99.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=34104
But I can beefed it up and made the stand for it by canabilizing an old Harbor freight engine stand.
icebird84
01-16-2009, 01:49 PM
any update , I hope you haven't give up
