View Full Version : Where can I find U-joints online?
Ripper
03-29-2007, 09:47 PM
I just bought a new drive shaft, but realised that I needed an adapter U-joint. The measurements should be;
Cap diameter (both ends) 27mm
Total width (one end) 92mm
Total width (other end) 82mm
I tried searching e-bay, but didn't find anything (don't really know what to search for, tried Ford & GM etc). Does anyone know where I can get these online?
Thanks!
Takid455
03-30-2007, 10:45 AM
ask the fellow that made it if he used 1330 or 1350 series u joints. if so most gm and ford trucks have either one. 1350 is teh stronger u joint. get them w/o grease fittings.
big gear head
03-30-2007, 06:24 PM
www.iedls.com
MonzaRacer
04-07-2007, 06:13 PM
is this built for a GM product or Ford?
This sounds like a standard conversion joint for GM with small caps I cantry to find my ujoint cataloge to get a number and see if I can help.
does the inside of the yokes on the driveshaft have a flat step to the inside of the yoke towards the tube ?
So this is an inside clip joint if it has grooves to the outside of the cap hole.
Which is it?
Lee
MonzaRacer
04-07-2007, 06:31 PM
According to my book this should match the NAPA part number 353 conversion joint:
US specs below and this is listed as one using outside lock rings:It is a combination of a 354 ujoint cross and a 369 ujoint cross.
Cap dimensions: 1.063" on all four crosses
dimension a (short cross from 369) 3.218
dimension b (long cross from 354) 3.622
I believe this a GM conversion joint and I believe this is the smae one I use in my truck.
Good luck
Lee
MonzaRacer
04-07-2007, 06:37 PM
Oh yeah there are a super strength joint NAPA number 275 which is greasable and another that is non greaseable NAPA number 253.
353 $19.99 USD
275 $26.99 USD
253 $$24.99 USD
I am not sure what availability you will have but these prices are from www.napaonline.com
good luck
Lee
Ripper
04-12-2007, 02:31 AM
Thanks for all your answers and help! I actually found the correct size on ebay and recieved it here in Sweden yesterday (total price was 30 $ incl. shipping! :yeah: ).
I mounted the yoke and drive shaft just to find out that the rear u-joint was a different size. :crying:
It's 92mm (3 5/8") over both ends, but one of the bearings are 27mm (1 1/16") diam and the other is 28,6mm (1 1/8").
I looked at ebay the other night, but couldn't find this version. Jegs has one that comes with four 27mm cups and two 28,6mm but Jegs don't ship with USPS and I guess DHL/FedEX/UPS to Sweden will be a considerably non-cheap way of shipping something that small...
Any ideas?
big gear head
04-12-2007, 05:24 PM
Most of the time you can swap the u joint cups. The outside diameter is the only difference. If you can find a u joint locally with the right size cups you might be able to swap them and make it work. I've done that before.
Ripper
04-15-2007, 10:53 PM
Yes, I tried this but the problem is the dust seals are different styles so I guess it won't work for more than a week or so...
I'll keep on looking.
