View Full Version : LT1 power steering pump with AN fittings
Samckitt
03-28-2007, 08:48 AM
How do I connect AN hoses to an LT1 power steering pump?
130fe
03-30-2007, 08:07 AM
I believe you need a 16 mm o-ring to AN6 (if you are using a size 6 line) fitting, if you are talkijng about the high pressure line on the pump. Call Paul at Hydratech, he knows all about the correct size info.
Samckitt
03-30-2007, 08:48 AM
Initially I was thinking the hose I needed it for was a slip on connection. Dummy me, that is the high pressure side & has a screw on connection. Won't be as tough as I thought. Does the outlet of the reservoir need to be higher than the inlet of the pump? Or just the fluid level higher than the inlet? If the outlet of reservoir needs to be higher, I may have a tough time finding a place to mount it.
