View Full Version : Do you think this will work?
jknight16
03-28-2007, 07:30 AM
As mentioned in one of my prior posts, I have installed a 9" rear in my 69, but the guy who built the rear-end left the companion flange yoke in it. So, originally I was going to replace the yoke with a more typical 1330 or whatever, and then do what is necessary to get the driveshaft to mate up.
However, I was sniffing around Currie's site and I found this item:
http://www.currieenterprises.com/cestore/productsre.aspx?id=1043
It's a companion flange adapter, that mounts to my big round companion flange and allows the driveshaft and u-joint I currently have to still work. Does anyone see any problems with doing it this way? Am I really taking the easy way out at the expense of performance/reliability?
Thanks guys
jknight16
03-28-2007, 07:54 AM
Ugh, nevermind guys, I just got a call back from Currie and they say it won't fit the old style companion flange I have. So nevermind that, guess I'll have to go the expensive route on this one and replace the yoke.
big gear head
03-28-2007, 12:49 PM
If you can get the other half of the companion flange that is on your 9 inch the you can use it. They just take a comon u joint.
jknight16
04-01-2007, 09:44 AM
I ended up having a new driveshaft built with the end that matches up with the companion flange yoke on my 9". The guys at D_ick's driveshaft in Phoenix had it built in a couple hours and now that it's installed I'm glad I went that direction. The companion flange assembly looks like it would be quite strong, but I'm no engineer so who knows.
Thanks for all your input,
JK
