View Full Version : 96 LT1 with wire loom, where to now
Footjoy
03-25-2007, 07:25 PM
I have 96 lt1 it has a wire loom but I am not sure what year it is off of. What is cheapest way to control this motor? I have 2004r or a 4l60e to run. Sould I stick with obdll or go with 94-95 set up. Unfortunatly money is tight what is neatest cleanest way to get this motor running. It is goin in 70 Nova.
Lawrence
03-26-2007, 03:53 AM
What year is your 4L60E? The 94's are different to the '95-96 (they have an extra wire for the PWM converter lockup). If you stay with OBD-II I dont think you will be able to control a '94 box, if you go OBD-I you can use a '94 flash for the '94 box, or a '95 flash for a '95 or '96 box. Hope this helps.
Footjoy
03-27-2007, 07:09 PM
thanks
69lt4
03-30-2007, 08:07 AM
I don't know much about there, but there are companies that convert the OBDII to OBDI. pcmforless.com, I believe does it. Check out their site and give them a call. Also, try camaroz28.com. There might be information there.
Kevin
Samckitt
07-03-2007, 05:47 AM
Call John Spears of www.speartech.com
