View Full Version : Mark VIII fan install questions?
whytry
03-23-2007, 07:49 AM
There are 3 wires coming from the Mark VIII fan, which 2 do I use? They are all black wires of same gauge. I know one is ground, and if I recall there other 2 are for the 2 different fan speeds, but I only wire up the higher speed wire. Also on my test fit install the fan hit the electric water pump, so how much can I safely trim off?
So I guess the million dollar questions are -
Which 2 wires do I use from fan?
How much can I trim off the shroud to get it to fit?
Mkelcy
03-23-2007, 08:27 AM
IIRC, one of the wires does nothing. I figured it out by jumping the two non-ground wires to a spare 12v car battery.
protour_chevelle
03-23-2007, 08:29 AM
the middle one does nudda if I remember right
whytry
03-23-2007, 10:18 AM
thanks guys!! Trying to wire it up now!!
gmachinz
03-24-2007, 08:06 PM
Hey, Brad. Yes, use the outermost wires for the fan-you can cap off the middle terminal on the fan. You can trim up to about 3/4" for clearance if need be. How much space are we talking? Can you mount it offset?
whytry
03-24-2007, 08:40 PM
On my BBC I had to trim about 1/2" from the shroud and offset it to get it to fit.... Had some other problems so did not get to try it out as I had hoped during the weekend trip, but it clears everything now and was a breeze to install with the SPAL controller, Thanks again Jabin!!!
CarlC
03-24-2007, 08:44 PM
https://www.pro-touring.com/forum/showthread.php?t=2418&highlight=dummied
