    Results 1 to 17 of 17
    Thread: Mice... Help!!!
      Mice... Help!!!
      Mice have gotten into my 67' firebird and are tearing up the interior. Granted the interior is going to be redone but I don't really want my project to become a hotel.
      I have also found droppings and a small chew whole in the seat of my 69' Chevy Shortbed... which is already restored. If I could only.... the little s.o.b's.
      I need help ASAP.... please any suggestions?
      Connecticut
      i have used mothballs. i put a trey of them in the front and back floor, also one under the hood and have had no trouble at all.
      Waverly, Kansas
      Quote Originally Posted by paulk68
      Ya just knew it was coming..........Is it hard to tell the difference between the male and female moths?
      moth balls
      I've tried that. I even poured them on the floor... all over!!!!!!!!
      I also put a bar of soap under the front seat and the little shi#$ ate half of it.... I think we have mutant mice.
      Aug 2001
      Connecticut
      I end up leaving decon and also those mice bait blocks in the interior and trunk- I had the headliner eaten when I first built the car, what was worse was the piss all in the cardbard that is in the roof-- yuck.
      1968 Camaro RS/SS, LS7 with Katech mods, T56 Magnum, C6Z06 Brakes
      1968 Camaro RS Convertible LS3/480hp/4L70E
      1962 Corvette 327-340hp stock
      1963 Corvette Split Window Coupe
      1967 Corvette L79 convertible
      2006 Corvette Z06
      2011 Corvette GS convertible
      Macon, Ga.
      The oldest way still works better than anything I have every tried. $2 mouse trap and $.20 worth of cheese will get them every time. We just rewired a motorhome that the mice had brought the green dcon INTO the coach and half eat it. That doesn't work, just pisses them off.
      Trust me, lowtech mousetraps work every time.
      Bill
      Trailers are for BOATS!
      CT
      Good luck,
      I was thought mothballs would keep them out.
      Looks like I better buy some traps just incase.
      Feb 2002
      Springfield, MO
      A better mouse trap?? Nope, just the cheapie like Bill said. Also, those sticky pads work great, but they do kind of stink. Get the little beggars out before they mate!
      Jimmy
      69 Camaro Twin Turbo'd
      58 Nomad 348 Baby Rat
      little falls minnesota
      5 gallon bucket, 3/4" dowl(just long enough to fit in bucket sideways),
      2 small nails, small set of steps(ramp will work),peanut butter,H2O.
      1-put nails in ends of dowl
      2-cut 2-small V's 180 degrees from each other on bucket rim.
      3-lay dowl across v's
      4-peanut butter installed in center of dowl
      5-install steps at one end of dowl
      6-fill bucket 1/2 full of H2O
      Can you say 'log roll'
      Southern Indiana
      Ok guys first of all you cant use decon if there is no water around(its activated when they drink not ate.
      Decon and use an old dog dish hub cap or favorite type cat bowl, put water out and Decon (the old flat box with poison oats) and then they dies.
      Lee
      Suisun City, Ca.
      The only thing with decon, you better find them when they die, or you will smell them for a couple of weeks.
      Mike
      Macon, Ga.
      Quote Originally Posted by mdprovee
      EXACTLY!!!
      They can eat Decon, then drink water, then crawl in some hidden crevious, and they will be stinking before you know they are dead, and then you have to deal with that. An old fashion trap kills them right now and the just lay there til you clean out the trap.
      Bill
      Severn, MD
      I agree that the old fashion traps work the best. Last winter I left a 3lb bag of grass seed in my shed, which backs up to the woods, not a smart idea. By spring there was about a half of pound left. Needless to say the shed became a very popular hang out for all of the neighborhood mice. In two weeks a got 18 mice with the snap traps.
      One hint that really works, put a little piece of cottonball under the locking lever. Their claws get tangled in the cotton while eatting the bait...works every time.
      Feb 2006
      Ambler, PA
      The dead smell eventually goes away.. then you'll find this....
      [/URL][/IMG]
      Jeff
      1969 Camaro RS Conv. 406sb, TKO 600, 12 bolt/3:55 Baer Brakes, 17" Budniks
      My Camaro
      NH
      Quote Originally Posted by 68sixspeed
      I had a 76 CAmaro back in high school, took it out of storage in the spring and I COULD NOT believe the smell! The mice had been using the area in the headliner right next to my head as a urinal. Had to tear it all out to can the smell.
      Beegs AKA Bryan
      NH
      Quote Originally Posted by pav8427
      I have a cousin that uses this method in his barn, it works! He catches mice on a regular basis. One thing he does is use a mixture of antifreeze/H2O to keep it in a liquid state throughout the winter.
      I have an excavator that for some reason acts like a Motel8 for mice. They at one point had chewed up all the wires for my gauge panel. PITA!! I tried mothballs and a few different old wives tale methods, none of that crap worked, started using snap-traps and have gotten eight over the winter. Problem solved.
      Beegs AKA Bryan
      Thanks guys... I really appreciate all the help. I think I will go with the regular old traps and I will give the "bucket of death" a try.
