View Full Version : engine casting #'s
Way_Fast_Whitey
03-21-2007, 01:34 PM
I found these blocks and wanted to make sure they are 350's. Could someone please help.
The first is 3970010.
The Moretec site says it could be a 302, 327 or 350. I found it in a late 70's truck.
The second is 387004.
I couldn't find any info on this one.
Thanks for the help.
Bubba
Van B
03-21-2007, 05:24 PM
3970010 350 from 69,70,71,72 Corvette, 302 from Camaro, 350 from 69-79 truck, 69-79 passenger car, Chevelle Camaro, Nova, Monte Carlo
387004 does not seem like enough numbers.
Way_Fast_Whitey
03-21-2007, 06:16 PM
Thanks for the info on the first one.
I looked pretty good and I think that was all of the numbers on the second one. It is in a old GMC van. Later 70's type.
pdq67
04-01-2007, 04:40 PM
Post the letters that are at the end of the VIN number string that is usually on the little deck pad that's right above the pass. side top w/p bolt and they decode to almost everything IF it is a virgin!!
Year, vehicle, engine size and hp, tranny, carb., air pump, etc.....
pdq67
Adam's 55 Chevy
04-05-2007, 09:59 AM
That casting number is probably the most common. It has a 4" bore for the 302, 327 & 350. If you want to build a 350 from it make sure the bottom of the block has clearance for the 350 stroke. If it is a full short block the shape of the raer of the crank will tell you what it is. Or measure the stroke of the piston.
