View Full Version : 1000hp 351 winsor?
BoBo
03-15-2007, 09:40 AM
I seen a guy on ebay selling a video showing that he can make 1000hp from a 351. Even if it's stroked and running nitruos, is that possible? Anyone with a stroked 351 (408 I think) think it's possible? And if you do have one what are you churning out for hp and torque?
:throw: <----like this one alot!
Goatman
03-15-2007, 09:44 AM
My buddy makes more with less ci.... Manny Buginga, do a Google. And he does it reliably.
What none of the nitrous guys will tell you is how many pistons they'll go through in a season to make the kind of power.
LowBuckX
03-15-2007, 09:48 AM
Ive seen windsor block split from stem to stern at under 500HP Ive also seen a few cranks not in the block but the main webing still attached.
1000 HP out of a windsor seems crazy
Goatman
03-15-2007, 11:03 AM
All depends on the power adder. A Boss 302 block is the minimum I would use though.
wantahertzdonut
03-16-2007, 10:09 AM
Depends on how much you want to spend. I don't know what the 351W blocks are good to HPwise, but it is higher than the 302 blocks which tend to split down the middle at about 500-550HP.
The 69-74 351W's have a higher nickel content in the iron and are stronger than other years of production. I've heard many good things about the 93-96 351W roller blocks as well.
Chad-1stGen
03-16-2007, 10:33 AM
The 302 blocks from 88-92 5.0 mustangs (might be off a year in either direction) are supposed to be supper high nickel content blocks too. Supposedly a lot of guys tear these down with 150,000 miles and cylinders don't need to be bored at all or even honed.
blown69nova
03-16-2007, 03:32 PM
If you're asking ,can you make 1000hp with 351 cubes?, the answer is yes. If you use an aftermarket block, you can do it reliably, if you use a stock block-you may only do it once!
Steve
bgm890
03-19-2007, 12:02 AM
1100hp+ is possible also. But it isn't cheap!!!
NOPANTS-68
03-19-2007, 11:18 AM
four digit power can be easily done, but the 351W block would not be the ideal way. A Dart block, AFRs and a healthy forced induction system would do the trick.
molyorange 77
03-19-2007, 12:44 PM
World Block,Dart there both good pieces, the best $2000-2500 you will spend period.
Goatman
03-19-2007, 02:52 PM
Ford just re-released the Boss 302 block which is just as strong as the others...
MonzaRacer
03-19-2007, 08:13 PM
Use the Motorsport block, build it over 400 cubes, make 750 hp and spray 2 stages of N2O 75 solid hit and and spray 175 on progressive.
It would be a beast.
Or buld it to make about 1200 on boost with a turbo.
Goatman
03-20-2007, 03:40 AM
From what I've heard, if you're going to use a turbo, you'll want less than 350ci....
Unless you're looking for more than 1400 hp.
Dave@RACEWARE
03-21-2007, 10:38 AM
We use to use an old Boss block and a 100mm turbo and made a 1500hp with ease. The best part is we ran that car for 3 years without changing a part except for headgaskets. The latest rage is big blocks with twins make 25-3000hp! Insane.
