View Full Version : Any try these on stainless tubing ??
67 455 Bird ragtop
03-09-2007, 01:00 PM
I'm looking to run hard stainless line along my frame for my supply/return lines for my fuel system. Stainless can be a real hassle to flare. I found these fittings by Russell for their aluminum line. They crimp on sortof like a compression fitting. I asked them if they can be used on stainless. They said on low pressure lines yes. Anyone ever use them ???
http://store.summitracing.com/partdetail.asp?autofilter=1&part=RUS%2D639230&N=70 0+0&autoview=sku (http://store.summitracing.com/partdetail.asp?autofilter=1&part=RUS%2D639230&N=700+0&autoview=sku)
Attached Thumbnailshttps://www.pro-touring.com/forum/attachment.php?attachmentid=15964&stc=1&thumb=1&d=1173360224 (https://www.pro-touring.com/forum/attachment.php?attachmentid=15964&d=1173360224)
jcs
03-11-2007, 06:48 PM
I used them on a 1/2" fuel line with Aluminum tubing, worked fine. I don't think they would work on stainless - it is too hard to 'give' enough to seal. Think of a compression fitting on copper plumbing, like an icemaker - the ferrule actually causes the end of the tube to distort to make the seal. I think stainless is even harder than mild steel, which is why I always fight to make stainless hard brake lines seal even though mild steel ones are leak free. I'm no expert, just my guess.
chicane67
03-11-2007, 07:14 PM
Swagelok (http://www.swagelok.com/search/find_products_home.aspx?RESET=TRUE) fittings are about the best thing for stainless there is... with no need to flare... and pressure handling capabilities that no other can come close to.
