72Z/28
03-02-2007, 01:49 AM
Hi guys
I have been doing some research regarding some heat barrier stuff to put on the firewall from inside because the interior gets very hot from the firewall and floor pans... areas
I have found a firewall insulation pad and carpet underlays from YEARONE..
So I wonder if some of you guys have used those pads like the firewall pad that fits directly behind the firewall.
here is the link to it
http://www.yearone.com/serverfiles/f...in2.asp?cat=8: (http://www.yearone.com/serverfiles/fbshopmain2.asp?cat=8:)
http://www.yearone.com/serverfiles/f...ain2.asp?cat=8 (http://www.yearone.com/serverfiles/fbshopmain2.asp?cat=8)
If so, how effective are they as heat barriers. I have read about Dynamat and Fatmat in (about DAYNAMT) thread. I understood from the replies that they don't work good or do a good job as heat barriers. Besides, lots of complaints about FATMAT customer service and shipping delays..
Last but by no means least, I am not familiar with how to remove the dash board in order to put the firewall insulation pad, any ideas ?? I do have the assembly manual from yearone, but the illustrations are not that good
Thank you guys in advance
