View Full Version : brake kit on ebay ....
robbie9999
02-28-2007, 09:02 PM
guys would this brake kit on ebay stop a 66 gto with 18's or 19 inch rims on it ?
has anyone used this kit on there car ....
or is better to go with a wilwood 12 inch rotor, with a 4 piston caliper set up ..would it be over kill plus its 450 more
http://cgi.ebay.com/ebaymotors/66-67-68-69-70-GTO-4-WHEEL-POWER-DISC-BRAKES-CONVERSION_W0QQitemZ290086569485QQihZ019QQcategory Z33564QQrdZ1QQcmdZViewItem
CSI:QUINCY
03-01-2007, 05:18 AM
are you plaining on racing the car or just driving. the willwood will look better but will not proform any better on the street. the ebay package will stop you goat on a dime. but just wont look as cool as a drilled and slotted rotor. I dont think willwood will proform any better on the street but on the track they will. want cool go with willwood or bear. want practical the kit on ebay will work great.
robbie9999
03-01-2007, 06:46 AM
hey mate thanks for the adivce .... I really am grateful! ... do you have experience with brake systems ....
for sure this ebay one will work ?
6'9"Witha69
03-01-2007, 08:58 AM
This kit is really no different from any MPP or other conversion package. And to say the wilwoods won't work as well on the street, no way. Maybe not the first couple stops in a trip, but once the heat builds up they will be much better. But that is all a function of pad compound. Wilwood does have a street compound which makes the overall compound difference negligible, but the larger rotors make a huge difference in leverage and WILL stop you faster than ANY factory style conversion kit. If you want to hit the track just switch out pads.
And while Xdrilled rotors look cooler, they are not truly performance pieces. This raises one the most heated debates this board can see.
robbie9999
03-01-2007, 09:22 AM
thanks mate for the advice - this guy Scott is willling to do the cross drilled as well .... basically if I do with this kit on ebay I am looking at 1100, instead of 1750 from wilwood ..... hmmmm
thats more money left over for suspension parts ......
