View Full Version : Question about valve cover flange
Mathius
02-28-2007, 05:18 PM
When fab'ing your own valve covers, can the flange be a flat piece? Stock covers usually curve down over the lip on the head. Is this necessary to prevent leaking, or can a flat piece be used for the flange?
Mathius
6'9"Witha69
02-28-2007, 05:22 PM
The lip helps keep the gasket in place when you are bolting it on. If you use studs it probably won't matter, just be careful in the corners and ends when you tighten it down.
