Yelcamino
02-28-2007, 03:53 AM
I'm not sure if this is the correct forum to post this in, but I'm picking up a 66 Chevelle SS396. It currently has a 396 (not the original engine) and I want to replace it with a 454 that I have. It's got L78 heads and was run on the dyno to the tune of 439hp/450tq. How much do you think I try to get for it? (I may keep the ignition system for the 454). Thanks.
Here's some specifics on the engine:
396, dyno tested - 435 hp 450 ft/lbs w/ carb straight out of the box, probably make more with some tuning
Block (#3955272)(T0916JB) .030 over (1969 Camaro 325hp)
L78 high perf rectangular port heads (#3919840) w/ new stainless valves and Comp Cams valve springs (924-16)
GM forged steel crank
GM rods, resized
Rotating assembly balanced
Hastings piston rings
Sealed Power forged pistons, +.030 (#L2242F30)
ARP head bolts (#135-3603) chromemoly black oxide
Comp Cams hyd roller cam (#11-430-8) lift: .566”, dur: 280
Comp Cams exhaust pushrods, (#7991-1)
Comp Cams intake pushrods (#8900-1)
Comp Cams hyd roller lifters, (#854-16)
Comp Cams rocker arm studs
Comp Cams Magnum roller tip rockers - 1.7 ratio
Comp Cams billet double roller timing set w/thrust plate (#7110)
Milodon 7 qt oil pan (#30950)
Enginetech oil pump (#EP77HV)
Enginetech oil pump shaft (#IS77)
Holley 870CFM Street Avenger carb (#0-80870)
Edelbrock Performer RPM Air Gap intake (#7562-R)
Mr. Gasket duel inlet fuel line w/ pres gauge (#1559)
Holley 110GPH mechanical fuel pump (#12-454)
ARP fuel pump push rod (#135-8701)
Fel-Pro gasket set (#KS-2618)
Pioneer harmonic balancer (#DA-396)
Sanderson headers, 3 qtr length, Jet-Hot Coated
Pro Comp polished aluminum valve covers
Polished alum breather cap kit (#WA6111POL)
Mallory Comp 9000 Unilite distributor (#9148201)
Mallory Pro Master coil (#29440)
Mallory Hyfire VI 685 Microprocessor controlled CD ignition system
MSD 8.5 wires (#35379)
GM rods, resized
