View Full Version : removing powder coating? hard?
muthstryker
02-25-2007, 01:23 AM
is it hard to remove powder coating? PITA? if you remove some of it can you re coat the bare area with the exsisting still on the parts?
BADVELLE
02-25-2007, 10:23 AM
Near impossible! If you can get it off, should be no problem with re-coating, however, if you can get it off.
CSI:QUINCY
02-25-2007, 11:49 AM
easyest way to get powered off is burn it off 2nd best sand blast. then yes you can recoat the areas that you striped.
nancejd
02-25-2007, 02:42 PM
I think Eastwood sells a chemical stripper that will remove powdercoating.
muthstryker
02-25-2007, 11:50 PM
hmm ok thanks guys, i was thinking sand blasting but dont know if that will affect the surrouding areas. unless they where masked off and then have it done. ill check eastwoods to see what i can find.
thanks
67Sally
02-26-2007, 08:44 PM
Check with your powder coater. I have heard that you can coat over a single layer of power coat.
W
