View Full Version : 67 Builder
67 Builder
02-22-2007, 01:27 AM
Hey guys I'm looking for some input. I have a 67 Camaro that I am getting started. Plan is to install a Lt1 or Ls1 with 6 speed. What can I exspect? I know this is gonna be a long process. I am looking for some advise on what to look out for or plan ahead on. I am also gonna up grade brakes and suspension. I am planning on using the stock sub frame. I pretty much need everything!!
I have heard that I can use a rack in pinon out of newer camaros. What yrs and what can I expect far as fitting. Same thing far as brakes off new camaros also. Any in for would be great
Thanks 67 Builder
Taylor1969
02-25-2007, 06:41 PM
Double Post
Taylor1969
02-25-2007, 06:45 PM
To give you a start... I went with the following on my car (which is maybe 40% done)...
I am trying to be as budget minded as possible while still getting great performance.
GW front and rear springs
C5 Front Brakes
ATS Spindles
GW Upper and Lower control arm bushings in stock arms
Rear LS1 brakes (brackets and rear shock relocation kit from BRP Hotrods)
GP Superstore for Body Bolt kit
IROC Steering box is in the works
1 1/8 Front Sway Bar
All new moog stuff (pitman, tie rods, etc.0)
18X9.5 rear wheels, 18X8 fronts
Aluminum Body Bushings from SpeedTech
Tubular tie rod ends from Speedtech
I'll try to post more when I think of more
prozoo
11-24-2007, 11:08 PM
I am doing the same car so keep the suggestions coming guys..
