View Full Version : Where to buy Weld through primer
BlackGMC
02-20-2007, 03:40 PM
Where can I buy weld through primer. I went to Oreilly's and home depot, hoping they could at least point to the right place but both people I talked to thought I was insane. "Why would you want to prime something then weld it", my response "Nevermind.....":hand:
John McIntire
02-20-2007, 04:01 PM
i've seen it for sale in Eastwood, but don't know what kind of time frame you need it in. Have you tried an auto body supply/paint store?
BlackGMC
02-20-2007, 04:10 PM
No I just started lookin today, I did not think it was a speciality paint. I will check out east wood. Any particular brand better than others?
Stan W
02-20-2007, 04:42 PM
You may have some luck at a welding supply store
wiedemab
02-20-2007, 05:58 PM
I'm not sure who would sell it in your area. In the Ohio Valley area we buy it from KOI.
Here is a link to the product. My Dad just used it on some rocker panels he's welding in. He said that it takes a little getting used to, but all-in-all it worked pretty well
http://autobodystore.net/Merchant2/merchant.mvc?Screen=PROD&Product_Code=UP787b&Category_Code=PRI
Brandon
BlackGMC
02-20-2007, 06:12 PM
Brandon
thanks for the link, man I did not know that it cost that much.
Satatic
02-21-2007, 02:34 PM
I got some of the cold galvenizing compound from eastwood. Its full of zinc and i donno it wokrs i guess. Its heavy, the quart can of it weighs about 10 pounds.
The thing i look at on most of these weld through primers is they say they can protect from months of outdoor storage. So i guess after a couple month you have to bust all your seams and reapply it?
67 455 Bird ragtop
02-21-2007, 02:43 PM
Home Depot does carry it. It's called cold galvaizing primer or something like that. I've used it several times.
BlackGMC
02-21-2007, 04:56 PM
Excellent, I will go check it out tomorrow. Thanks!
BRIAN
02-21-2007, 08:22 PM
3M stuff is great but clogs constantly. It and many off brands are available at your local Autobody supply. Some of the cheaper brands work better. I am using some crazy Greek, yes Greek brand (Im serious) that works great so far. Also tastes good on a Gyro. go figure.
HTP I believe sells a brush on version.
Just to make sure, you only use it in panels that are being spot or plug welded together. If you are trying to run a bead in it it is like welding in mud and not it's intended use.
Also wear a respirator!!!
marty69212
02-24-2007, 06:16 PM
walmart dude!!!!!
65convertSSl79
09-25-2014, 11:53 AM
http://www.finishing.com/85/35.shtml
Wait, I thought welding on galvanized metal was bad?
Simbad68
09-25-2014, 03:08 PM
NAPA Auto Parts carries it in Martin Senour paint.
Build-It-Break-It
09-25-2014, 10:55 PM
I would Hope the OP would of found the primer by now, this thread was from 2007......
minendrews68
09-26-2014, 09:29 AM
:lol:
1truckguy78
09-27-2014, 04:26 PM
Just finally found some myself today at a swap meet.
