View Full Version : 69 camaro rear disc break
igotthegmachinebug
02-18-2007, 08:57 AM
considering buying the morrison front sub frame . i am wondering is there a c 5 vette break kit for the rear of the camaro or does it really matter who,s rear break i run.
Widetracker
02-18-2007, 09:42 AM
https://www.pro-touring.com/forum/showthread.php?t=26850
www.brphotrods.com has a c5 rear brake adapter bracket. I only know that from the previous thread.
neki67
02-18-2007, 10:54 AM
http://www.kore3.com/proddetail.php?prod=10277
Hammered
02-18-2007, 10:56 AM
I've been researching the h@!! out of this setup and believe that you can get sufficient shock clearance by running the C5 rotor instead of the LS1. The C5 rotor requires the backing plate and caliper to be moved outboard another 1/2" Of course this could cause interference with some wheels.
The BRP brackets are for LS1 rotors, not C5, but can use a C5 caliper with minor modification.
igotthegmachinebug
02-18-2007, 01:45 PM
wow i have the wilwood kit on now with bolt in axles and i had to use axle housing clamp brackets welded in place to use the breaks as the tires are like 1/3 of an inch from the fender now maybe even closer. and all i have for rear tires is the 275/40/18 and im filled them c5 breaks will never work for me
Hammered
02-18-2007, 01:56 PM
The wheel doesn't get moved out further, only the caliper if you use the C5 rotor.
$Mike70Z-28
02-18-2007, 02:30 PM
wilwood has a kit for the back and you dont need to relocate the shocks and with the e-brake
ProdigyCustoms
02-18-2007, 02:57 PM
The Morrison Chassis does not come with brakes, but it is set up for C5 brakes.
